Problem whit the tilt away function on the steering wheel
Hello,
The tilt away function on my steering wheel dosent work, the electrical adjustment works fine, but when you push the button and activate the function nothing happends? what can it be? i have looked under the steering wheel for lose cable but all looks fine, is there a relay for this function?
regards.m
regards.m
Ok, u also have a RS6?
I found a relay missing under the steering wheel. Slot nr 3. I went to audi and asked them what nr 3 is for and they said its for the solar panel, but maybe its in the same relay...can you check if you have the relay in place, if u have solar panel?
I think the relay have the nr 385 on the top, and the part nr is: 4b0959589
regards.m
regards.m
Capt.BluePearl
Apr 1, 2012 10:57 PM
JustWondering
B7 Models
Sep 11, 2011 11:17 AM
