*****A few problems******
Old Apr 10, 2006 | 01:14 AM
hondaEater's Avatar
Default *****A few problems******
2001 S4 w/99,000miles
I'm getting some hard starts when I start it cold, I'll turn the key and it will turn over but not start, turn the key off then try it again and it starts right up. Spark plugs are new. What could this be?
Second problem is I replaced the tbb and noticed that there was a little oil in the bi-pipes, I have no idea if thats normal. I'm guessing not, cause that would mean that oil is traveling through my intercoolers from the turbos and into the bi-pipes, in that case wouldn't I run hot because of the oil going through the intercoolers, but I'm not running hot. I dont know, what do you guys think I should do? There was no oil in the tb just the bi-pipe.
Old Apr 10, 2006 | 04:03 AM
BadLuckAudi's Avatar
Default RE: *****A few problems******
that oil is normal, nots turbo cars get it.... as for starting maybe check the ignition module
Old Apr 12, 2006 | 02:38 AM
dankhound's Avatar
Make sure your vehicle is maintaining fuel pressure. If its not holding fuel pressure after you shut the vehilcle of it can lead to hard starts. Small amounts of oil in the intake tract is normal.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
