'01 S4 no start.
Old Aug 16, 2008 | 02:09 PM
CamoA6's Avatar
Default '01 S4 no start.
Alright, so I go out to the S this morning go to start it and nothing...Cranks hard but no start. and then I notice the battery voltage is just barely dipping below 12volts. and I know thats no good. I tried cables once, but no luck.
I'm thinking Alternator. what do you think?
Old Aug 16, 2008 | 04:14 PM
CamoA6's Avatar
a friend also just asked about the fuel pump...possible?
Old Aug 16, 2008 | 06:22 PM
drev500@aol.com's Avatar
deffinantly not the alternator because it has no function during start up. Start with the basics and see if plugs are sparking and your getting fuel to the cylinders.
Old Aug 17, 2008 | 12:21 PM
CamoA6's Avatar
Im thinking of just doing a big overhaul before it goes away for the winter. Cam belt (im at 88k) plugs, air filter, fuel filter, fuel pump, and injectors. of course I will also check them first.
Old Aug 17, 2008 | 01:23 PM
Mott Power's Avatar
turn on the car but don't crank the engine, let the fuel pump build pressure first
that is a pretty low reading for the battery, but the fact that it still wouldn't start when you jumped it is odd, too
do you hear the cylinders fire at all or is it all just the starter motor?
Old Aug 17, 2008 | 04:28 PM
CamoA6's Avatar
Im just getting crank noise. but i just went out to check fuses and such and i put the key to the on position and noticed no check engine light.
Old Aug 17, 2008 | 07:50 PM
CamoA6's Avatar
So just talked to a audi porsche tech of 35 years. and he said we should test the ignition switch tomorrow. Ill post back tomorrow evening with any news.
Old Aug 19, 2008 | 11:42 AM
CamoA6's Avatar
update:
I put in an extra stock ECU and it fired right up. Looks like I have to hit up the classifieds and find myself a new chipped ECU. but what should I go with? I have APR 93 right now. I heard GIAC was nice though.
As of why this happened. I do not know yet. Ill be opening it up once im back in the shop.
Old Aug 19, 2008 | 05:57 PM
lilnickx69's Avatar
For the ecu chip i have heard any stories about the solder on the apr chips breaking off causing the chip to not function probably. If your apr chip isnt flash and it has been soldered there is a very good chance that the solder is making contact and the ecu chip is shorting out. Call up apr and send it in to them as i beleive they have a lifetime warranty.
Old Aug 19, 2008 | 07:20 PM
CamoA6's Avatar
yeah, thats what my boss said.
My APR chip is infact a flash though. I opened it up and looked. al that was in there was writing inside saying "ECS 11/04"
I know the chip was purchased through ECS. I gave APR a call and they still haven't called me back. I will probably just overnight them my ECU. we'll see what happens.
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
