2000 S4 brake bleeding?
Old Feb 5, 2007 | 12:06 AM
AudiS4_190's Avatar
Default 2000 S4 brake bleeding?
I'm having a problem w/ my brakes the pedal goes all the way down when I try and stop. I knowit is somthing to do with bleeding the brakes. But I don't know how to bleed them on the S4. from what I hear it is different from the A4. It's not the normal way to bleed them. ( pumping the pedal ) please help!!
Old Feb 5, 2007 | 02:02 AM
TKneedsS4's Avatar
Default RE: 2000 S4 brake bleeding?
Idk you mgiht be right , however when i re did my brakes about 3 months ago all we did was bleed them regularly with the pumping method and i have no hicups yet.
Old Feb 5, 2007 | 03:19 AM
2k S4's Avatar
Just the normal brake bleeding procedure works fine.
They don't just go to the floor. You might have a bigger problem. Your master cylinder might be going out, or you might have a leak in the system.
How much fluid is in the reservoir?
Old Feb 5, 2007 | 11:49 PM
ThePapaCMan's Avatar
I'm pretty sure there's a right up about it on audiworld. That's what I used a while back and it solved the problem when my fliud went too low because of a bad rear caliper.
Old Feb 6, 2007 | 03:32 PM
GeilKyle2's Avatar
2k's right sounds more like a master cylinder piston seal issue if it just happened all of a sudden
Old Feb 6, 2007 | 05:36 PM
chebert69's Avatar
If it has to do with bleeding your brakes, get your hand on a power bleeder.
you'll be able to do it all by yourself. Check on ECS tuning .
Good luck
Old Feb 12, 2007 | 09:50 PM
AudiS4_190's Avatar
took it to the mechanic and he couldn't bleed it at all he tried like 3 different ways. He said it's the master cylinder. So I ordered it off ECS today. W/ over night shipping it is still $40 cheaper then audi!
esrest
Jan 20, 2013 10:17 PM
makav3li
Apr 18, 2010 10:52 AM
410ThirtyValve
Feb 3, 2009 11:44 PM
Lsand
Aug 2, 2007 12:29 PM
moeron7
Apr 6, 2007 07:53 PM
