2000 S4 pcv replacement
Old Mar 9, 2011 | 10:21 PM
evelluser's Avatar
Default 2000 S4 pcv replacement
So I was just on ecstuning, perusing through stuff when I came across this:
It looks like they changed out the PCV valve with a small breather filter. 1) am I correct in assuming thats what they did? and 2) what would be the benefit of doing that as compared to keeping the PCV valve?
Old Mar 10, 2011 | 04:11 AM
FonzoB5S4's Avatar
it appears what they did was put in an oil catch can w/breather filter. the benefit to this is catching most of the excess oil that gets into the y-pipe, intercoolers, etc. pretty much helps to prevent blow-by. i think it might be a morosso catch can w/breather.
i'm looking into one of these myself. vast has a kit and so does 42 draft design that are pretty nice. this one is probably custom.
Old Mar 10, 2011 | 06:32 AM
evelluser's Avatar
So then would the catch can replace the PCV and get rid of the need to hook it up to the y-pipe?
Old Mar 13, 2011 | 12:57 PM
evelluser's Avatar
http://www.maperformance.com/jm-fab-...catch-can.html
So I've been lookin online and found this one. It says in the description that I can use it to replace the PCV valve. How exactly would that work? Would I just run a length of hose from the catch can to the intake without the PCV in the middle? Or am I still required to have the PCV?
Old Mar 13, 2011 | 05:33 PM
FonzoB5S4's Avatar
ok. this is where i am not 100%. i'm pretty sure its a straight up replacement for the stock pcv system. so it should plug in the same places the pcv system does. i just ordered one from vast. when i get it and instal it i'll have more info.
here are some custom set-ups i'm trying to get inspiration from.
http://www.audizine.com/forum/showth...Oil-Catch-Cans!
Old Apr 9, 2011 | 03:50 AM
TWiST2k's Avatar
This is my first post here, I am a long time az'er. I am wondering if you ever recieved your setup and if you had some info on it and what all it replaces. My spider hose is shot and I need to replace it and ive got quite a bit of oil in my DV hoses and Y pipe. So I wanted to add a catch can to it, I just was not looking forward to spending money on a new spider hose and a catch can kit.
panicandrew
Oct 16, 2014 01:10 PM
pashagtp
Aug 22, 2011 05:17 PM
cracker289
May 10, 2010 08:01 AM
rdepoo
Apr 26, 2009 11:19 AM
Brandon2000s4
Aug 26, 2006 10:46 AM
