2001 audi s4 Tranny big problem
Old Mar 23, 2008 | 02:51 PM
TSMS4's Avatar
Default 2001 audi s4 Tranny big problem
i crashed my 2001 audi s4 6spd. Everysince i crashed it its harder to switch gears and my 1-2 gears grind ... now it doesent want to go into 1st or 2nd gear at all but goes into all the toher gears but barley i brought it to the mechanic and they fixed it but i happened again i want top know what it might be becuase my mechanic is fixing it for free but he cant figure out what it is .... HELP!!!!
Old Mar 23, 2008 | 06:07 PM
Brandon2000s4's Avatar
Default RE: 2001 audi s4 Tranny big problem
Syncros is what it sounds like to me.
Old Mar 23, 2008 | 10:08 PM
skeezo3000's Avatar
Start with looking at the clutch master and slave. I couldn't get into gear becasue my clutch master was siezed. This was after I had my trans rebuilt so check that out before you rip your trans out.....But synchros are a common issue
Old Mar 25, 2008 | 12:29 AM
ballistic69's Avatar
It's the 1st to 2nd gear shift collar. See the link below.
http://shop.jhmotorsports.com/produc...p;productId=74
Kirt
Old Mar 25, 2008 | 03:22 PM
e8myshrts's Avatar
Your shift collar is mushrooming the syncros and will eventually wear away the engagement teeth on the 2nd gear.
http://www.advancedautomotion.com/pr...products_id=37
There are several versions of the collar and the syncros, and only certain syncros will work with certain collars.
Old Mar 25, 2008 | 03:43 PM
readimag's Avatar
yeah or jsut check if when you crashed you lost some tranny fluid or maybe you need to replace your syncros, mine did that all i did was replace the fluid and was fine.
FilthyTT
Feb 4, 2014 11:40 PM
Nemick
Sep 11, 2012 05:33 PM
nakata
Nov 12, 2010 10:23 AM
Deanne
Nov 1, 2007 06:45 PM
