ABS CPU location
Hi,
I have problem with finding the ABS ECU. Usually it is located on the ABS pump, but not on my S8 year 2000.
There is no communication with VAG, abs light is on, and the big stop signal turns on after 10s or so.
As it has ESP sw, I think the abs cpu is inside somewhere.
HAs dicmantled all around the back seat and in the boot. The fuse in the boot area was burned, replaced, but still the same.
Also tried to locate it around the steering wheel, but no luck. Some experts said, that it should be next to the steering column, just next to the accelerator, but it is not there...
Any idea, where it is? Some picture would be awesome.
Thanks
Thanks
