Aftermarket DV installed, is it working?
Old May 15, 2008 | 04:04 PM
Blue Jay's Avatar
Default Aftermarket DV installed, is it working?
Ok, so I installed an aftermarket diverter valve set onto my car to go with the APR chip. Before I replaced the valve, I could hear a little "PSST " noise as I shifted, which I assumed was the valve blowing off. I changed to an aftermarket valve (Stratomsphere I think), and cranked it to the full 1.0 bar, and now I can't hear any blow-off.
I am worried that the valve is not actuatting properly, but the car is running fine. Are aftermarket ones just quiter sometimes? It was a lot larger, metal, and more substancial.
Old May 15, 2008 | 04:57 PM
audi ops's Avatar
Default RE: Aftermarket DV installed, is it working?
Are you sure the ones you replaced were dv's not blow off valves. Also, that sound could have been a bad rubber diaphram leaking which is bad and now you are getting a complete seal. Don't worry your fine if its running well, however I do remember those being louder than other dv's and run mostly by a4 folk.
Old May 15, 2008 | 11:08 PM
Blue_S4's Avatar
DVs do NOT make noise............read the stickies!!!!!!!!!!!!
Old May 16, 2008 | 09:01 AM
Blue Jay's Avatar
I know they aren't supposed to make noise, I was just a little worried because the stock valves made noise, and then I switched, and the noise went away. I just wanted to make sure it was running right.
Old May 16, 2008 | 11:12 AM
Blue_S4's Avatar
thats a good thing....the stock DVs probably had a torn diaphram.
Old May 16, 2008 | 06:35 PM
JohnnyS4's Avatar
Mine to were making that noise but when i installed new ones it went away, This is normal. I miss the pssst. Thinking of gettin the hybrid dv`s .
Kenjuro
Mar 18, 2009 05:52 PM
Audi_Skydiver
Aug 6, 2007 03:35 PM
