Airbox topside sensors.
Old Oct 29, 2007 | 01:12 PM
CamoA6's Avatar
Default Airbox topside sensors.
This morning I changed my oil, and replaced my airfilter, and when I reinstalled everything and started the car it felt like my MAF was way out of spec. (misfire codes, lean running codes) so I went through everything again and found that one of the plugs ontop of the airbox were loose. (my bad) I believe it was the passenger side plug closest to the front of the car. What are these plugs doing?
Old Oct 29, 2007 | 02:04 PM
techbod's Avatar
Default RE: Airbox topside sensors.
hopefully this will help MAF sensor would be my guess
Servicing Motronic injection system[/align]Fitting locations overview[/align]
â—†Diagnostic connector
â—†Fuel pump relay
(relay position 4 in central electrics under dash panel insert, left hand side) [/ul]
4 pin connector
â—†For lambda probe 1 (G39) [/ul]
3 pin connector
â—†For knock sensor 1 (G61) [/ul]
Coolant temperature sender (G62)
â—†On coolant pipe behind cylinder head, Bank 1 [/ul]
Throttle valve control part (J338) [/ul]
Intake air temperature sender (G42)
Intake manifold change-over valve (N156)
4 pin connector
â—†For lambda probe 2 (G108) [/ul]
3 pin connector
â—†For engine speed sender (G28) [/ul]
3 pin connector
â—†For knock sensor 2 (G66) [/ul]
Engine control unit (J220)
Fuel pressure regulator[/ul]
Hall sender (G40)
â—†Cylinder bank 2 [/ul]
Lambda probe 2 (G108)
Engine speed sender (G28)
â—†In gearbox housing above starter ring gear [/ul]
Knock sensor 2 (G66)
Camshaft adjustment valve 2 (N208)
Ignition coils (N, N128, N158)
â—†With output stage (N122) [/ul]
Knock sensor 1 (G61)
Injector (N30...N33, N83, N84)
Hall sender (G163)
â—†Cylinder bank 1 [/ul][/ul]
Lambda probe 1 (G39)
Earth connection
â—†On engine support, right-hand side [/ul]
Camshaft adjustment valve 1
(N205)
Air mass meter (G70)
Activated charcoal filter solenoid valve 1 (N80)
â—†On air cleaner [/ul][/ul]
[IMG]local://upfiles/12092/BE20F58D5D8D40BFBDAF65C7E2C90822.jpg[/IMG]
Old Oct 29, 2007 | 02:06 PM
CamoA6's Avatar
Yeah, I got the problem fixed. I saw the plug loose and plugged it back in and everything back in. Thanks for the sheet
Old Oct 29, 2007 | 08:22 PM
2k S4's Avatar
They are ignition control amps. One for one bank, & one for the other.
Old Oct 29, 2007 | 08:37 PM
Scott Long's Avatar
that picture looks like it's a 12v 2.8L
trickyniki02
Mar 26, 2010 10:10 AM
Schroeder
Jun 26, 2008 06:11 PM
xbrian87
Aug 14, 2006 10:58 PM
a4autocrossr
Jul 25, 2006 01:19 PM
Dunzie182
Apr 19, 2006 10:26 PM
