anyone ever damage an intake valve on a b5 S4.... fawk
anyone ever damage an intake valve? dont know how i did it, i ran a comp test and got 50psi in the left front cylinder "the only one misfire'n"
did a leak down and its leaking through the intake, so i am guess'n maybe i over rev'd and nicked / damaged a valve? burnt maybe? broken spring?
anyways, it smokes sometimes out the exhaust pretty heavy, usualy after i boost it good or drive for awhile then come to a stop, i thought i had blown a turbo but i guess not,
anyways if you guys have any ideas or advice that would be great, the motor idlles quiet like it should, no ticking or anything,
i am about to go stage 3 and yank the motor.... just wondered if this was common, i cant find any similar posts on audiworld..
Or if something, like a nozzle from a W/M kit gets sucked through the engine:
It's the one in the middle on the right. And it doesn't look really bad but it was actually causing a 0 PSI compression problem. Not a fun deal.
Josh
Josh
gabeguimaraes
May 22, 2009 04:46 PM
