b5 s4 6spd flywheel specs
Old Feb 4, 2009 | 02:07 PM
bigern45's Avatar
Default b5 s4 6spd flywheel specs
Ok...ive got my southbend kevlar disc in and i just got my rs4 pressure plate and im getting ready to pull the tranny...my question is...is it a must to cut the flywheel...and if so...im gonna have to cut both levels on the flywheel...the pressure plate bolt on surface as well as the actual clutch to flywheel surface...so what is the spec? how much distance is there to be between the two levels? ive searched and cant find it...thanks a lot...
Old Feb 4, 2009 | 02:56 PM
drev500@aol.com's Avatar
when you say cut you mean resurface? If so there is no real spec. You just have to cut enough off to remove the glaze. If you dont know a place or dont know how to vast sells resufaced flywheels with a core deposit for a good price and it comes with the fly wheel bolts and a new pilot bearing I believe. http://vastperformance.com/shop/prod...products_id=60
Old Feb 4, 2009 | 06:08 PM
bigern45's Avatar
no.. i can resurface the flywheel, but because there are two steps.. the actual surface and then where the pressure plate sits, i thought that you possibly had to machine both surfaces so that the clutch would not have too much pressure or not enough... if the distance between the two areas do not matter and i dont have to take any off the pressure plate resting area then i will just do the flywheel myself..
Old Feb 9, 2009 | 01:30 AM
oh but you do ahve to take off material off the pressure plate mounting surface. However much you take off the friction surface is the amount you take off the pressure plate surface
ajy4490
Oct 8, 2008 05:14 PM
Bigrigatoni
Jul 3, 2007 10:22 PM
gino123
Sep 14, 2006 06:42 AM
PhoneixFire13
Mar 5, 2006 11:29 PM
blast
Apr 6, 2005 11:33 AM
