b5 s4 troubleshooting
Getting some lovely error codes, have misfires mainly on cyls 4 5 and 6, have replaced coil packs spark plugs and the icms are fine.
Car is stock minus piggie pipes, 62k on the clock.
17861 (P1453)---Unknown Trouble Code
16684 (P0300) Random Misfire Detected
16690 (P0306) Cylinder 6 Misfire Detected
16689 (P0305) Cylinder 5 Misfire Detected
16688 (P0304) Cylinder 4 Misfire Detected
16805 (P0421) Warm Up Catalyst Efficiency Below Threshold (Bank 1)
16685 (P0301) Cylinder 1 Misfire Detected
16686 (P0302) Cylinder 2 Misfire Detected
16687 (P0303) Cylinder 3 Misfire Detected
17537 (P1129)---Unknown Trouble Code
17965 (P1557)---Unknown Trouble Code
im ordering an egt tomorrow but other then that im not exactly sure where to go from here
need to vag it brother, that way you can get the OEM specs on those codes. some of those codes may be the key to your answer. and sometimes the egt's wont set a code, but they will glitch, cause poor drivability and black smoke out the tail pipe from running rich..
Two of the unknown codes are running to rich, and the last is a faulty EGT sensor on bank 1.
Other then ordering EGT, i dont know what would cause the misfires....
a bit more info...
cars getting around 13-15 mpg, misfires increase on idle versus under load....
no large amounts of smoke or anything.... hesitates under WOT/anything other then light acceleration.
a bit more info...
with egt code setting, whenever you're under boost/load then timing is pulled and fuel is dumped super rich, hence, misfire codes. fix the egt and you should see most of these issues clear up. oh.. and btw.. go ahead and get both of them, as the other is sure to follow..
a bit more info...
a bit more info...
Last code has nothing to do with misfiring. 17965 is more likely a boost leak in the system:
http://wiki.ross-tech.com/wiki/index...5/P1557/005463
But as the article explains, can be other things too.
Pressure test your system with one of these :
http://www.turboboostleaktesters.com...%29/Categories
Pretty cheap for a well made model.
Good luck
Good luck
Well good news and bad news.
misfire was handled due to sensors.
but......the previous owner had the car with a leaky headgasket, ended up toasting the bottom end due to a shortened rod.
needless to say the bottom end seized on me one night when starting my car in my driveway
now parting out my baby.....since it doesnt make financial sense for me to fix.
