B6 S4 still will not start
Old Sep 22, 2012 | 11:51 PM
srlito's Avatar
Default B6 S4 still will not start
About two weeks ago the car lost all power driving down the road and would start up kinda but very rough idle. So i had it towed home to figure out what was going on. When i turned the ignition on i did not hear the whine from the fuel pump so i went under the dash and checked the fuse for the pump and to see if the relay was clicking over and made sure that there was power going through it which ultimatly led me to getting a new fuel pump( and filter since its been a while). I installed all of that today and to no avail it will just crank and not actually turn over. Its also not throwing any codes which tells me its not the crank position sensor. Ive double checked all of the connections to the pump and the filter. If anyone has any other ideas what would be wrong would be greatly appreciated before i have to take it to the stealership on monday so i can take a road trip back down to San Diego.
Old Sep 23, 2012 | 07:52 AM
z28pete's Avatar
Have you checked for spark, and tested fuel pressure with a proper gauge?
Old Sep 23, 2012 | 02:37 PM
srlito's Avatar
I will be checking that shortly.
Old Sep 23, 2012 | 05:37 PM
srlito's Avatar
Car is running now. Switched up two lines on the fuel filter but now I'm misfiring on 5 and 6 throwing P0300 P0305 and P0306. Time to check the plugs and and coil packs.
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
