blower motor just stopped working
Old Aug 7, 2008 | 02:39 PM
pepsicolla's Avatar
Default blower motor just stopped working
I let my parents take my car for a weekend while i was away. When i came home the blower motor wasnt working..rrrrrr. WTF did they do?
I'm getting 13-14 volts to the blower motor. (5 pin connector, 2 larger gauge wires). Its a constant voltage with the climate control on or off. Im assuming the other 3 wires are control voltage from a potentiometer of some sort.
I ohmed out the motor and connector from the climate control and referred back to my brothers s4 for reference. All values are pretty much the same.
I tried using the climate control diagnostic that i found on here somewhere, but it doesnt seem to make any sense to me. does anyone have a suggestion?
Its awful hot and i'd love to kick the A/C on. HELP
Old Aug 7, 2008 | 02:42 PM
pepsicolla's Avatar
A schematic would be great if anyone knows where i can find one. I have a program thats supposed to be like haynes and others but it shows me nothing about the blower motor or control voltage. crap program
Old Aug 7, 2008 | 08:05 PM
auditech79's Avatar
Its probably the motor, take the motor out of your brother's car and hook it up to your electrical connector and see if it works.
Old Aug 8, 2008 | 12:09 AM
meatbiscuit's Avatar
You check for codes? You can scan the climate control unit with the VAG.
Old Aug 8, 2008 | 09:34 AM
pepsicolla's Avatar
I have vag-com but it says it cant communicate with the controller. Is my vag-com up to date? theres actually a few things that dont seem to work with my vagcom...i bought the cheapy vag cable and loaded the drivers.
Old Aug 8, 2008 | 09:36 AM
pepsicolla's Avatar
If the motor was bad shouldnt i have popped a fuse? Unless the motor shorted "open" which is pretty uncommon. I'll try my brothers motor.
Old Aug 8, 2008 | 12:30 PM
auditech79's Avatar
No you wouldn't have popped a fuse, blower motors going out isn't all that uncommon on audi's. Ive replaced a few hundred of them in my day. Not being able to communicate with the a/c control head worries me, but that could be that your using a cheap cable as well.
Old Aug 8, 2008 | 01:45 PM
pepsicolla's Avatar
ya thats kind of what i figured. My vagcom is suspect.
My concern is the ohm readings from a confirmed "working" blower. My blower ohms out exactly the same.
ill see.
Old Aug 10, 2008 | 05:40 PM
drev500@aol.com's Avatar
If you would wait till the 25 when im back at school, I could get you the schematic but im figuring you should have it fixed by then.
BigLunch
Feb 4, 2025 09:51 PM
dendrizzi
Jun 8, 2008 04:33 PM
pimpinaudi90s
Jan 27, 2007 04:19 PM
jfrish
Dec 6, 2006 04:12 PM
jfrish
Oct 30, 2006 01:44 PM
