Boost gauge question
Old Jan 26, 2007 | 03:30 AM
Brandon2000s4's Avatar
Default Boost gauge question
Well today i finally installed my blitz dual turbo timer. the one with a boost gauge. and i was wondering what hkPa means? Also if anyone else has this, can you change the background color?
Old Jan 26, 2007 | 03:47 PM
2k S4's Avatar
Default RE: Boost gauge question
http://www.hkpaowto.org.hk/eng/home.html
Sorry not sure Google knows either.
http://www.mr2.com/ARTICLE/BlitzTT.html#oper
Old Jan 26, 2007 | 06:15 PM
thanks for the info...im a noob at the whole turbo thing...first turbo car...how do u convert hkPa to psi?...i was also wondering if anyone knew what the stock level of the hkPa...mine has peaked at .78
Old Jan 26, 2007 | 06:32 PM
nvm. noob question...i figured it out by searching...1 bar = 1 hkPa..so im running about 11.3 psi stock...sound right?
Old Jan 26, 2007 | 06:52 PM
Superdug's Avatar
SoCal Crew Member/White Devil
I thought it was around8 p.s.i. stock but that is very unconfirmed
Old Jan 26, 2007 | 09:23 PM
Flip's Avatar
1 bar=14.7 psi, so if you are running 1 bar you should by right around 15 pounds of boost.
Old Jan 26, 2007 | 11:23 PM
2k S4's Avatar
ORIGINAL: Brandon2000s4
You should peak about 11ish, & taper around 9-10psi till redline.
However air intake temp can change the boost a little. So if it's really cold out it will be lower, & if it's hot out you will run a little more.
Old Jan 27, 2007 | 03:15 PM
Hano's Avatar
just multiply your reading to 14.5. that will be your reading in psi from hkpa. i have the same turbo timer as you, it's amazing. you can't really change the background light, but there was a guy on ebay who sold turbo timers after he changed the led lighting to match the audi red interior lighting. the peak boost hold option is really nice i think. that way you can just go WOT and check your boost later. and i'm currently pushing 1.51 hkpa.... or 21.9psi
Old Jan 31, 2007 | 04:30 PM
Hey Hano, you know the bars at the top of the boost gauge? the ones that jump? What do yours say when your idling? mine sit around 4-5 at an idle. I was wantin to make sure i ran it to the right line.
Old Feb 1, 2007 | 03:47 PM
Coop's Avatar
kpa = kilo pascals
supergoober752
Dec 22, 2009 10:03 AM
TT4fun
Oct 23, 2008 01:45 PM
LuckyCharmsUXZ
Mar 31, 2007 11:34 PM
khj677turbo
Aug 8, 2006 11:23 AM
Vader
Sep 21, 2004 01:18 AM
