Brake Troubles - Sudden Pulsation
Old Dec 31, 2007 | 06:15 PM
RCFerrari's Avatar
Default Brake Troubles - Sudden Pulsation
Hello,
I have a 2001 S4 with a few mods but nothing crazy. The car has newer rotors and pads with less than 20000 miles on them. There is a pulsation coming from the front driver-side when I hit the brakes.
The funny thing is that this was completely fine yesterday and all of a sudden there is a major pulsation like the rotor is completely warped but that couldn't happen over night. Its like something broke or snapped. I don't think it is the ABS sensor because the pulsation is more like a dud-dud-dud-dud-dud rather than a grinding ABS noise.
I did a visual inspection and everything seems fine, I also cleaned the brake assembly with brake cleaner but no good news.
So, any chance anyone ran into a similiar problem?
Thanks,
RCF
Old Dec 31, 2007 | 08:36 PM
shawncumberland's Avatar
Default RE: Brake Troubles - Sudden Pulsation
does the dud-dud-dud-dud-dud occur even when your not on the brakes?
does the dud-dud-dud-dud-dud change with speed?
I'm leading to a possible bearing gone bad...
Shawn
Old Dec 31, 2007 | 10:47 PM
RCFerrari's Avatar
That bearing assembly (the entire axle) was just replaced less then 10K miles ago.
The dud-dud-dud happens only when applying the brakes moderate to hard.
Like i said, this just started this morning, damn car was absolutely fine the night before. [:@]
Old Dec 31, 2007 | 11:59 PM
JETSPEED333's Avatar
SoCal Crew Member
alot can happen to the front brakes in 20,000 miles..... i would re-check all bolts to make sure they are at specified torque and change/re-bleedthe brake fluid if that has not been changed...
Old Jan 1, 2008 | 06:31 PM
RCFerrari's Avatar
Any other suggestions out there before I disassble and reassemble this brake assembly?
Old Jan 2, 2008 | 03:50 PM
2k S4's Avatar
Just try to rebed the pads. You might have some build up on them.
You find a nice road where you can go up to 60 & brake hard a few times, then do a couple moderate stops, then drive around to cool them off.
Old Jan 2, 2008 | 08:16 PM
RCFerrari's Avatar
Fair enough... I did already try the braking technique but that didn't work. However, I will reseat the pads and etc.
fratzke7
Jun 24, 2011 10:03 PM
cb2100
Dec 11, 2009 07:51 PM
theTTkid
Mar 31, 2007 02:47 AM
quattrocket
Nov 22, 2005 05:09 PM
aho
Aug 10, 2005 03:46 PM
