car issue help..
Old Jul 19, 2006 | 02:28 AM
sooks's Avatar
Default car issue help..
So a couple weeks ago i had a very rough start where it started very harsh and idled rough but was fine after a minute or two but it also through the cel. Well i was already scheduled to go to the shop the next day so i just had them clear the codes since it was running fine. i know a few of the codes had to do wiht a misfire. Well recently it has been still idling rough will fluctuate occasionaly between 800-950 rpm and sort of shake as well as when im coming to a stop. As well as at idle im only at about 18 inHg compard to usually at 22. i still reach about 20 lbs boost under WOT and off throttle at about 26 inHg and during shifts it seems a bit harsh right at the shift. Does any one have any ideas off hand what the issue could be? any help would be appreciate.
Old Jul 19, 2006 | 02:48 PM
FourDs's Avatar
Default RE: car issue help..
Sorry sooks. Not ignoring you...just no idea.
Old Jul 19, 2006 | 02:59 PM
sooks's Avatar
yeah.. i dont know..
I have 3 ideas.. as i havent got to look at it yet..
1. vac leak somewhere.. Seems to me it could be running lean.. and with a vac leak the turbos will work harder giving me full boost normally..but under idle getting less vaccuum.
2. bad/old spark plug or misgap.. if its just not firing correctly ..obviously
3. doubt it..but potential maf.
Old Jul 19, 2006 | 05:50 PM
Hano's Avatar
sorry sooks. i wish i could help, but i am drawing a complete blank.
Old Jul 19, 2006 | 06:01 PM
techbod's Avatar
idle control valve/sticking throttle flap or TP sensor
Old Jul 20, 2006 | 05:20 PM
sooks's Avatar
Avant.. That did come up with a discussion between me and my friend while we were thinking waht it could be with teh throttle position sensor...
Do you have any ideas what would be a good indication that that may be it.. Im still looking to get on a vag here soon.. do you knwo what codes will show for that if any.
Old Jul 20, 2006 | 07:26 PM
d5coupe's Avatar
have you done a throttle body adaptation?
you can rule out alot of those possible causes by logging with VAG
what DTC codes caused the CEL?
Old Jul 20, 2006 | 07:56 PM
sooks's Avatar
tryign to get on a vag by the end of the week...
nelson0639
Dec 8, 2014 04:44 PM
hotswaps
Aug 8, 2013 05:50 PM
hotswaps
May 27, 2013 07:02 PM
Dallas09
Feb 14, 2009 05:08 PM
2001A6
Jan 9, 2009 02:41 AM
