Clicking noise...sometimes...front right side
Old Nov 12, 2008 | 08:22 AM
DSMKiller's Avatar
Default Clicking noise...sometimes...front right side
So i was driving the wifey to work yesterday when i noticed a pretty loud clicking type noise coming from the front right wheel? I pulled over had a look, could not see anything wrong...reversed for about 20 feet than foward again. It went away. Did the same thing when i picked her up. drove, started clicking than i reversed than no more noise. Im guessing a wheel bearing? I just had my front cv axles replaced about 1500 miles ago so they should be good. noise fades when car slows down. It sounds like a bad bearing...any ideas?
thanks
Old Nov 12, 2008 | 06:56 PM
SVOSHOP's Avatar
In my experience with bad wheel bearings, you should get a growl or hum while driving down the road. By turning the wheel, like a lane change, it should decrease or increase the noise. Helping you point out what side has failed. Double check the axle boots are not torn. You may pull the wheel also and assure the axle nut is tight.
Mike
Old Nov 12, 2008 | 07:06 PM
Minnis's Avatar
bad CV. check the boot for crack- telltale sign of dry joint. Did you have reman. put in?
Old Nov 12, 2008 | 08:39 PM
mys4.org's Avatar
If for example its a clicking noise while going around a turn then for sure a torn cv boot. If anything jack the car up and see if there is any play if you try to physically move the wheel. If there is no play then you need to check the cv boot.
Old Nov 13, 2008 | 11:41 AM
DSMKiller's Avatar
I do not know if they where remans or not. Hopefully not. I will have time tomorrow to put it on the lift and see whats going on. It's not a hummm for sure, but a loud clicking, similar to the clicking when a bad CV when you turn the wheel, but when it make the noise when driving straight and does not get louder when you turn the wheel. I just had CV's put in 2 months ago.
Old Nov 14, 2008 | 05:01 PM
DSMKiller's Avatar
OKay, I took the wheel off for some inspection to see what the hell was going on. I looked at my cv's. Where the cv bolts to the tranny, there was 1 bolt missing and the collar that balances the "spin" still hadone bolt in it and the colooar was bent to **** was causing the noise. Brought it back the jackasses who put them in and said that they should never come out. I said bullshit, three of the bolts where loose and 1 missing. He said they used locktight.
Old Jul 17, 2011 | 10:26 AM
SuperSage's Avatar
Default front right wheel clicking
Im having a clicking problem around my front right wheel. BUT its
if i am coasting. Its fine under acceleration and braking. It happens
whether im in gear or not in gear. Has anyone had this problem or know
what it may be? Let me know...
Thanks
Old Jan 3, 2019 | 08:38 PM
Paul Sanz's Avatar
Thanks
i have this same problem, did you ever figure it out?
Old Sep 28, 2020 | 11:59 AM
Nick Brook's Avatar
Did anyone find out what was causing this? I’ve got exactly the same issue.
Old Oct 8, 2022 | 05:55 PM
smithw1's Avatar
I've also got the same issue on my '07 RS4. Almost sounds like a heat shield rattling, but I've looked everywhere. Has loud clicking from front passenger side related to speed of tires over 35 mph when coasting, not accelerating. Happens regardless if I am in gear or not. Seems to amplify when hitting brakes, which is a bit different from the above post. I replaced the CV axle, and removed and inspect the brakes, no help. Does not have to do with turning... happens when going straight. Please help... need to get this car back on the road.
Mr. Phil
Sep 11, 2009 07:35 PM
duganc
May 4, 2009 08:30 PM
Suicide Bobb
Sep 18, 2008 12:03 AM
kolbs_91
Aug 27, 2007 07:05 PM
motorhead
Mar 14, 2007 07:32 PM
