condensation in headlight
Old Jan 4, 2009 | 03:46 PM
cdetS405's Avatar
Default condensation in headlight
Both of my headlights have condensation in them, covering most of the headlight, is there anything that can be done to prevent this or clean them?
Old Jan 4, 2009 | 04:17 PM
RED_01's Avatar
You can remove your lights and place them indoors for a while with all the bulbs removed.
You can speed this process up by blowing a warm hair dryer through the bulb holes.
The only way to prevent the moisture from returning after you get rid of it is to seal up
any and all leaks they may have.
Whether the leak is in the lens or in the housing, a clear 2-part plastic epoxy works great for this.
Are your lights OEM or aftermarket?
Old Jan 4, 2009 | 06:05 PM
cdetS405's Avatar
OEM lights
Old Jan 4, 2009 | 07:26 PM
RED_01's Avatar
Originally Posted by cdetS405
OEM lights
Well, that's odd then.
Old Jan 4, 2009 | 09:46 PM
bottlecap's Avatar
you could always upgrade to ecodes when you get the extra cash
Old Jan 5, 2009 | 11:39 AM
Blue_S4's Avatar
warm air from hair dryer, like mentioned, and check for cracks or separation between housing and lens. make sure your 2 black covers on back still have the rubber o ring in them, and that your turn signal still has a rubber o ring around it. if any are missing, replace, cheap and easy fix then.
Flip
Jun 29, 2008 11:20 PM
certifiedimports
Oct 8, 2007 03:12 PM
Joeski
Oct 19, 2006 11:36 PM
aho
Jun 6, 2005 06:40 PM
