Difference between S4 and RS4 engine?
Old Mar 28, 2008 | 06:03 AM
JValentine13's Avatar
Default Difference between S4 and RS4 engine?
so whats the real main differences between the S4 and RS4 engine.. the V8 (new) ones.. if i was going to get like a 05 S4 could i get RS4 internals and would everything from a RS4 work on the 4.2? or maybe even R8 internals haha.. just kinda curious...
Old Mar 28, 2008 | 09:56 AM
Blue_S4's Avatar
Default RE: Difference between S4 and RS4 engine?
the R8 is the RS4 engine....no difference other than the computer.
as for the s4 v rs4, the cam is different, the pistions are lighter and make a higher compression, higher flow intake mani/heads, different fueling, better exhaust, etc.
Old Mar 28, 2008 | 05:01 PM
JETSPEED333's Avatar
SoCal Crew Member
could you put an RS4 cam into the S4??? ...to bad it's way too much freakinwork to replace the camshaft...this V8 ain't no honda.....
Old Mar 28, 2008 | 06:04 PM
Blue_S4's Avatar
my guess would be that you can do that....but you will probably want an engine tune with it just to keep the audi smoothness there
Old Mar 28, 2008 | 07:28 PM
pdq 5oh's Avatar
Just changing the cams probably wouldn't help, might actually hurt.Cams are ground to work within specific parameters. Air flow, compression, RPM range, gearing, fueling,etc. I bet you'd lose bottom end, too. Like Blue_S4 said, there are lots of differences that all work together to make more power. I've seen many people put in big cams, only to get smoked by people with smaller cams, in better combinations.
Old Mar 28, 2008 | 08:31 PM
Blue_S4's Avatar
^^^^agreed!
rmr1499
Sep 15, 2013 03:45 PM
DSG ROCKS!
Apr 21, 2010 10:09 AM
domnf15
Aug 6, 2009 11:46 AM
juxsa
Dec 23, 2008 08:18 PM
golonaus
May 28, 2007 04:29 AM
