diTranny Problem
Old Nov 27, 2006 | 06:31 PM
Brandon2000s4's Avatar
Default diTranny Problem
Alright well I tried to get on it today and i ran it through first...and when i went to shift into 2nd it made a hellacious noise...like i didnt push the clutch all the way in but i did and its only in 2nd gear...every other one is fine..i have to push it all the way to the floor to shift into 2nd if im getting on it..any ideas?
Default RE: diTranny Problem
i didnt mean to put di...typo
Old Nov 27, 2006 | 11:50 PM
DevilS4's Avatar
1st to 2nd gear slider/syncro problem most likely. Check the shifter adjustment also. Are you having any reverse issues?
Old Nov 28, 2006 | 03:49 PM
ya sometimes it wont go in reverse....i have to try it a few times then it finally goes
Old Nov 30, 2006 | 02:32 PM
How do i fix a slider/syncro problem? and how do i check the shifter adjustment?
Old Dec 1, 2006 | 06:33 PM
GeilKyle2's Avatar
to fix a synco problem you will have to replace or rebuild the tranny. If I were you and you keep experiancing the problem first i'd try some GOOD new tranny oil. No cheap stuff. BGsyncoshift, redline, sometimes some new oil can work wonders
Old Dec 1, 2006 | 08:12 PM
Mott Power's Avatar
Common problem mate. I know you may be short on cash considering you replaced your clutch recently and whatnot, but look into a rebuild by Stasis Engineering. Pretty costly but WELL worth it. Just take it easy on the tranny, from what I've seen it only gets worse.... depending on how you treat the car.
Old Dec 2, 2006 | 12:23 AM
DevilS4's Avatar
My reverse detent on the shifter pretty much fell off and was keeping my shifter from going completely into gear. I'd pull the cover from around the shifter and see how things look. Check for any debris. I was prepared to pull the tranny and have it rebuilt a couple months back and all I needed was a clip for my shifter.
Old Dec 2, 2006 | 05:13 PM
Alright ill go check it out...and I will let yall know what is causing all this...thanks for all the info
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
