DIY basic tune up question-
Old Jun 10, 2006 | 07:01 AM
i3uddha's Avatar
Site Moderator/Ninja
Default DIY basic tune up question-
Well, I'll be taking the car in a few months for a timing belt change...
but in the mean time wanted to do some basic DIY tune up stuff (ie: spark plugs, fluids, cabin filter,)
any other tips or suggestions while im fiddling around under the hood?
car is about to hit 80k
Old Jun 11, 2006 | 05:12 AM
Hano's Avatar
Default RE: DIY basic tune up question-
do the timing belt replacement yourself. you can find a complete timing belt kit at ecstuning.com. the only audi specialty tool you shall need is a cam lock bar. this way you will be saving a TON of money.
Old Jun 11, 2006 | 12:32 PM
FourDs's Avatar
I think you should try to negotiate the price down with an indy first, regarding the Timing Belt change. Also, post where you live here and on Audiworld, and ask for the best shop in your area. I think with some diligence and negotiating, you can get this job done for the 700-800 range, rather than accepting that it just costs $1200 no matter what you do.
Then, the question is would you rather pay someone 700-800, or pay 250 + cam locking bar (there was just one on here for $100, but I think they cost a bit more than that usually) + any tools you don't have.
I decided to have the job done by someone else. Got TBelt maintenance with parts, valve cover gasket change with parts, and oil change for $1,000.
IF you decide to do it yourself, go to this link http://homepage.mac.com/edyjun1/S4/index.htm. That page is amazing. Do a search for timing belt, and there is a whole write up on it.
Good luck either way!
Old Jun 11, 2006 | 12:44 PM
techbod's Avatar
its not a tune up your doing its a main service, if you intend doing the timing belt do the tensioners and water pump regardless if they need doing (peace of mind) if the water pump goes you will wish you listened unless its been done not so long ago
Old Jun 11, 2006 | 07:09 PM
i3uddha's Avatar
ORIGINAL: avant80@2.6
no sure where every1 got the idea that i needed help on the timing belt.. sorry let me make it clear again...
Im doing some tune-up maintenance - needed some feedback -
I'm gonna prolly do - cabin filter, fluids, plugs, just wanted to see if anyone had any other suggestions...
I'm having the timing belt / serpentine belt / water pump etc etc. all replaced next month... just wanted to do some basic
maintenance till then is all...
Musky Cat
Aug 11, 2015 03:34 PM
norcal89451
Feb 9, 2013 01:00 AM
89MustangGX
Nov 24, 2008 01:54 AM
02A4Turbo
Aug 18, 2008 11:33 PM
thetryal
Jul 20, 2007 06:01 PM
