Drive Train Stabilizer Question
Old Oct 4, 2007 | 02:39 PM
jpace31's Avatar
Default Drive Train Stabilizer Question
Ok guys when I first got my B5 S4 I noticed the very common play in the drivetrain - drives me nuts! The new snub helped a little, but I think I may have a broken trans mount. So, I'm looking into some type of Drive Train Stabilizer, but I'm wondering if I need to verfiy that all my mounts are good before installing it.
In other words if I have a bad trans mount is it a bad idea to install a DTS, or will the DTS just assume the workload of the broken mount???
Thanks!
Old Oct 4, 2007 | 06:27 PM
2k S4's Avatar
Default RE: Drive Train Stabilizer Question
It really doesn't matter, it will help a lot, but you should make sure the mounts are good.
Old Oct 4, 2007 | 06:31 PM
jpace31's Avatar
Ha, come on 2k...mixed signals???
By the way I just saw some interior pics of your car on another thread.....that thing is ridiculous. Your a lucky man!
Old Oct 4, 2007 | 06:59 PM
2k S4's Avatar
ORIGINAL: jpace31
Sorry, I mean, if you have bad trans mounts, it will not really help. But it does stiffen things up when everything else is working properly.
Old Oct 7, 2007 | 03:01 PM
S4speedfreak's Avatar
You will def. reduce upshift and downshift reliability I have one. Its really helps on movement of motor but you always should have good mounts because that will lead to other failure of things. if you rev the motor up it shouldn't shift that much or shake, if your getting more movement and shake than what seems normal check the mounts
Old Oct 13, 2007 | 02:40 PM
jpace31's Avatar
If I rev in neutral its pretty solid....so maybe the mounts are alright.
Old Oct 13, 2007 | 11:26 PM
thats a good thing!!
mattbracing
Sep 8, 2008 07:59 PM
m5racer
Jan 29, 2007 11:09 PM
juju4uofa
Jan 12, 2007 03:40 AM
ESE Tuning
Aug 9, 2006 04:51 PM
juju4uofa
Jul 22, 2005 11:31 PM
