engine difference? tip vs manual
Old Jun 16, 2007 | 05:46 PM
shawncumberland's Avatar
Default engine difference? tip vs manual
Let me give you a little background.
I called to talk to APR in regards to their stage III kit for 2000-2002 S4's for a project of mine. I have not bought the motor or tranny, but I was leaning towards picking up a tip S4 as for I could find a better deal and most likely less ragged out. My original thoughts were to get the motor and tip and then eventually pick up a manual tranny if needed. The guy at APR basically blew me off with the we don't deal with tip's have a nice day. So before getting off the phone I asked the question of why are the upgrade packages slated as for 6 speeds only and he quickly blirted that the motors are different. The motors are different?!?
This is news to me, I am a newbie to the audi world, but as far asI knew the motors were the same, just the trannies are different. Needless I looked on ETKA and the blocks are in fact different part numbers for tip and manual.
The question is, what are the differences in the blocks? transmission mounts?
Thanks,
Shawn
Old Jun 18, 2007 | 12:17 AM
Default RE: engine difference? tip vs manual
with 24+ visits I was hoping that someone would at least say "yeah, their different", or "what are you smoking", or "holy sh3eoot, I didn't know that either"...
Something guys, why the different part numbers for TIP blocks and MANUAL blocks? What is the difference?
Thanks,
Shawn
Old Jun 18, 2007 | 01:01 AM
joshpsu's Avatar
motors are the same.. 99% sure.. also APR does not deal with TIPs... my indy mechanic is APR sponsored and they make no software for TIP, you have to go GIAC or REVO..
dont believe everything people tell you
Old Jun 18, 2007 | 02:55 AM
Woodhead2k's Avatar
APR is retarded because they think a stage III tip can't exist. They might say they're kit wont fit on the tip... but it will. For a manual you upgrade the clutch/flywheel and for an automatic you just have to built the tranny. When you build it, you just replace the steels and clutches with strong ones and a harder shift kit. I've heard the tip is better geared for the 1/4 mile so if you plan on making some a lot passes a tip wouldn't be a bad idea, even though a 6-speed is just as good. I got the same reaction when I first talked to APR
Old Jun 18, 2007 | 08:51 AM
Thanks guys, sort of what I figured with APR, might look into an AWE stage III anyways. 2bennett.com sells a bulletproof race track proven tip, a bit pricy though...
Old Jun 18, 2007 | 11:20 PM
Dr.S4's Avatar
ORIGINAL: shawncumberland
Gess thats wat APR have turned into lately, givus u money then **** off![:@]
F**K APR!
There are no diff b/w tip & 6spd motors, just the vaccum and PCV system is a tad diff, but no biggy
Go strait to GIAC get the Stage III kitand u will be very happy - at least they have got software for the TIP
Dnt know wat APR are thinking not catering for the TIP market? as u can make the TIP S4 pretty fast down the quarter mile with a trans brake
Wot bout all those guys who have TIP A6 and Allroads and would like a more agressive program for the tranny? GIAC!
Old Jun 19, 2007 | 01:23 PM
2k S4's Avatar
The engines are the same, minus the ECU (the big problem) & a couple of emissions things (secondary air pump).
Back in the day, every one thought the TIP was weak & could not handle the HP of STGIII, now it seams, the 6sp are the ones that break.
There are some K04 TIP code out there. GIAC, VAST, & ASP all make K04 code for the TIP.
rmr1499
Jan 28, 2013 07:24 AM
Boostfreak94
May 27, 2012 12:22 AM
domnf15
Aug 6, 2009 11:46 AM
JValentine13
Mar 28, 2008 08:31 PM
parkertseng
Jan 21, 2006 01:58 AM
