FMIC fitment.
I have a RSR front bumer for my b5 s4, went with the RSR because mudflap flew off of a truck and broke the stock one and the RSR looks better and was alot cheaper anyways. I wanted to know if the JHM FMIC will fit behind the RSR bumper with the grills installed. I have seen a few that have fit the FMIC behind the bumper but the grills arent in idk if they have the grills out to help run cooler or if it wont fit or just a mixture of the two. If anyone knows if they can fit even with further modification that normal.(bending pipes or shortening etc..) i would apreciate it.
i dont know much about the bumper and or fitment. i just have a comment on the FMIC on the S4. I did a lot of research because this was a mod i wanted to do as well. I found that if your going to be doing a lot of city driving it is not the best setup. Having th FMIC requires you to remove the fan that is in front of your car. German cars are like a high maintenance girlfriend and they don't like there **** messed with. you might run into so higher running temps with the FMIC, also you are now going to have more piping leading to delayed spool up times. You have a lot of nice mods on your car and i would sugest going with the AWE side mounts and put the mesh in the RSR bumper cuz it looks sick. Also this way your car will maintain the sleeper look. Dont know if that is even a issue with you though. any way that was my two cents.
