Foglight/turn lamp
How do you replace these? I haven't gotten a good look, but is it as simple and pulling the actual bulb housing (not headlight) and sticking in a new bulb for the turn lamp, and the fog light, do you have to go from under the car or what?
yes..it is that simple.
for the foglight..you just remove the grill.. and you can "i think" take the bulb out from the back. or else you can unscrew it and take out the whole assembly.
Is it just a maze game in order to get to the turn lamp housing? Also How do you take the fog light grille off. It is wet out so I don't want to lie on the ground to get a closer look.
what do you mean a maze game.. you shoul be able to just unscrew it from the back.
and just pull the grill off.. it may seem like it wont want to come off..just pull harder..it will.
From looking at it it seems the one that has the turn lamp is far back, its the passanger side one so the airbox is right there and seems like a right fit.
And just pull hard enough to pull the grill off that the fog light is on? Well I guess if you say so lol, I usually don't like just yanking things off...but.. yeah...
i know i know..it seems weird and i was nervous my first time.. the foglight isnt actually attached to the grill. just pull from the horizontal bar that goes across the front.
may be easier to remove the headlights..although one of the bolts is a biotch to remove and put back.
