front axles
Old May 22, 2007 | 08:27 PM
s4treet rat's Avatar
Default front axles
hello my name is jason and.....
my boots on the front axles are old and riped and i am going to change the 2 myself dose have a clue to if you need specialty tools to get the job done right my car is a 2000 s4 2.7 bi turbo 6 speed. If you could help me i would appreciate thanks
Old May 23, 2007 | 12:52 PM
2k S4's Avatar
Default RE: front axles
It's really, really, really, messy. Did I mention it's a messy job? The easiest is to purchase rebuilt axles.
Off the top of my head, you need basic hand tools & a jack. You remove the center cap on your rim, then remove the 19mm or hex bolt in the center, it's like 300ft-lbs, so you will need a breaker bar. Don't remove the bolt, just about 75%
Then jack up the car, remove the wheel.
Then with a mallet, hit the 19mm bolt on the axle, this will slowly push the axle out but not all the way.
After the the 2 upper control arms, the pinch bolt holds them in, so it must be removed, spray it with some penetrating spray.
Now you can pop out the axle, cut the metal bands holding the boot on. remove the CV joint & clean it out, clean it all out. (very, very messy)
Then repack with grease, pop back on, put on the boot, & put on the clamps, or use big zip ties.
Button it all back up, torque the axle nut last, then put back in the wheel center cap.
Soldier Boy
Apr 30, 2015 01:07 AM
le0.br4zuc4
Aug 15, 2011 11:11 PM
aaronholoster
Jun 23, 2011 04:37 AM
Doug from Anchorage
Oct 15, 2010 10:28 AM
jayraudi9
Apr 11, 2008 07:29 PM
