Gas mileage question
Old Apr 26, 2007 | 07:25 PM
auS4di's Avatar
Default Gas mileage question
I noticed slight smoke coming from my engine and i took it in to the shop and was told i have a small cam seal leak. they told me the car was fine to drive and since i'm in school, i decided i would wait until the summer to have it fixed. in the mean time, my gas mileage has been cut in half almost. i am barely getting 12mpg city. could this be due to the leak? from what i understand, the leak is very small and only allowing small drops of oil to escape. could the problem be more complicated than the shop thinks? any input is appreciated! btw, the car is a B5 S4. thanks again.
Old Apr 26, 2007 | 07:39 PM
techbod's Avatar
Default RE: Gas mileage question
I doubt that small leaks would effect the mpg in that way, perhaps a full service is in order also check for any fault codes or you have a fuel leak
Old Apr 27, 2007 | 03:29 AM
2k S4's Avatar
The leak isn't causing it. The VCG are around 6hrs of labor to replace & $75 for the gaskets. So it's not a cheap job.
For the gas thing...
Check all the filters, & most importantly, the CTS, it will cause this & the car will drive fine.
Old Apr 27, 2007 | 11:28 AM
auS4di's Avatar
thanks for the input, what/where exactly is the CTS? i'm not worried about the cam seal replacement (covered under warranty), which i'm assuming is the VCG? i know enough, just not too technical with the shorthand terms. thanks.
Old Apr 27, 2007 | 02:05 PM
2k S4's Avatar
ORIGINAL: auS4di
Coolant Temp Sensor.
A4Alan
Apr 14, 2011 01:15 PM
kovalchuk71
Mar 4, 2007 02:01 PM
omar501
Nov 20, 2006 09:26 PM
choraltech
May 13, 2006 03:38 PM
crusininda944
Dec 20, 2005 04:07 AM
