Got Codes, need opinions please
Old Oct 30, 2007 | 08:51 PM
carhopper's Avatar
Default Got Codes, need opinions please
I'm getting code P0431bank 1 below threshold. It started out only happening about once a month, but now comes on and stays on. No affect in performance or gas mileage. I read that this is sometimes caused by a secondary air injection vacuum leak. I checked for leaks in my system and none. Do I have a bad CAT? Precat?
Old Oct 31, 2007 | 11:58 AM
2k S4's Avatar
Default RE: Got Codes, need opinions please
If you have a 6sp there is no SAI, it most likely a O2 starting to fail.
Old Oct 31, 2007 | 12:07 PM
techbod's Avatar
P0431 warm up catalytic converter, bank 2 - efficiency below threshold
causes are cat, wiring, HO2S 2 ( heated o2 sensor 2 )
Old Oct 31, 2007 | 10:12 PM
carhopper's Avatar
OK, thanks. Which O2 sensors or sensor is failing. Do you generally replace all 4.
Old Nov 5, 2007 | 02:30 PM
CamoA6's Avatar
sensor will probably soon throw a code. then replace that one. (for example Oxygen (lambda) sensor B2 S1 : open or short to ground)
B=Bank
S=Sensor
Old Nov 5, 2007 | 02:38 PM
CamoA6's Avatar
Also if your cat is bad and your under either 80k or 100k I believe it is under warentee
cocomazzy
Feb 25, 2012 02:34 PM
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
exoticmix27
Jan 13, 2010 04:13 PM
pentool
Aug 2, 2007 02:45 PM
