Having some trouble
Old Dec 26, 2007 | 08:35 PM
drobrt's Avatar
Default Having some trouble
For those of you with aftermarket radios installed, I need your help! First of all I have the Bose Symphony radio. I went out and bought the metra kit that included everything, wiring harness, antenna hookup, and the dash kit. And after modifying the plastic kit a bit I got my DVD player to fit in properly. Then came my wiring. I wired everything up the same as I did in my previous car, but I don't get any sound coming out of my stock bose speakers. However, my telephone speaker plays music perfectly?! So I connected some ear phones to the wires before they got to the audi amp, and I could hear music playing. So my question is, is there a wire I'm missing that sends some code to the audi amp. Any help would be appreciated. I've doen some searching on the site and others, but I can't find a solution to my problem. And is the K-line something to do with my problem?
Thanks, Derek
Old Dec 26, 2007 | 08:56 PM
ARIaudiS4's Avatar
Default RE: Having some trouble
im not 100% sure but i know when i changed my system i changed the headunit and the speakers, amp and sub. I heard that if you have bose then you need to change all the wiring to hook up a new system. maybe thats why you are getting no audio.... you cant use the stock speakers with new wires and headunit
Old Dec 27, 2007 | 01:39 AM
drobrt's Avatar
Yea, I'm hoping that isn't true, but it seems like that is probably it. But I read on another forum that someone managed to get the aftermarket headunit to work with the stock amp. I'm going to look it over better tomorrow.
Old Dec 27, 2007 | 03:13 PM
drobrt's Avatar
Ok, well I wouldn't call myself an electronics noob, but I certainly made a noob mistake. I "Thought" I had grounded everything, but forgot that Audis use a ground loop that was connected to the back of the old radio. I figured grounding everything else a different way would allow me to cut out the stock grounding plug. Well as I was fooling around with the radio, I happened to touch the metal on the radio to the metal frame in the dash. And Vwala! I had sound coming out of my speakers. So I ended up attaching a clip to the new radio and hooked it up to the stock grounding plug. So I figured out the problem to my question. But there is a little bit of static coming from the speakers, so I'll have to investigate to figure out a way to eliminate that noise. But I'm glad I figured it out.
mcj2400
Feb 26, 2013 03:59 PM
ang7610
Jun 15, 2008 10:58 PM
msimsi
Jan 27, 2008 08:07 PM
audi9605
Dec 29, 2006 02:54 PM
abdi21
Aug 16, 2006 09:00 AM
