HELP! check engine light
Old Aug 16, 2007 | 09:12 PM
readimag's Avatar
Default HELP! check engine light
Hey I went to my local autozone and got these codes pulled after a 300 mile drive, the CEL jsut poped on.
17521 bank 1 sensor 1 resistance too high
01113 error occurs intermittant
16684 misfire reconized
16687 cyclinder 3 missfire detected
16686 cylinder 2 misfire dectected
16891 idle speed control system rpm desired valve
16689 cylinder 5 misfire dectected
can someone please tell me what it all means in dumb speak and what i am looking at to fix. all i can gatther from it is my o2 is bad and i think it was over reved, but i could be all wrong
Old Aug 17, 2007 | 11:20 PM
readimag's Avatar
Default RE: CEL Codes HELP!
So the CEL just went away after a fill up and a quick burst of speed on the high to pass a car. had autozone check it again, and now there are no codes, WTF is going on i am way lost, and i fucked or was it jsut a fluke. any help will be greatly appreciated. and now the damn thing has come back on after like 2 days of it being off, i guess i will check what the codes are this time, oh and also what does this button doin the picture below.
http://armstrong.facebook.com/photo....mp;id=69700767
if you cant get on the web site it is the button just to the upper left of the shifter it is just a on off switch for something to what no idea please help!
Old Aug 21, 2007 | 02:46 AM
techbod's Avatar
as you suspected its the ISC ( RPM higher than expected ) problem is the throttle control unit,
all the other codes are probably caused by this and the O2 sensor is only doing its job by detecting the misfire so I doubt its that,
appols for taking so long to answer ive been away for a few days
Old Aug 21, 2007 | 06:57 AM
readimag's Avatar
thanks! well that is what i figured it was so i changed it out and now i am still getting miss fire on the cyclinders so i figured i will just change out the plugs and see it that clears it up. thanks again
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
