Help with codes....
Old Jul 19, 2007 | 10:03 PM
Ruggedboy's Avatar
Default Help with codes....
I purchased the car from a member on the forums, who lived in GA. I drove the car back up to NY with no problems at all. To tell you guys the truth I love this car. I wanted to see if I could get some info on these codes:
P0422 – Main Catalytic, bank 1 below threshold
P0300 – Random/Multiple cylinder misfire detected
P0422 – Came on the trip back home. I got the car to work & checked the code, I erased the code & it didn’t return.
P0300 – Came one today, I also erased the code, but this one came back on after I turned the car on & off a few times. Is this as simple as spark plugs or something else.
Old Jul 20, 2007 | 12:27 AM
2k S4's Avatar
Default RE: Help with codes....
Might be a failing EGT sensor, or a clogged cat.
Old Jul 20, 2007 | 11:30 PM
Ruggedboy's Avatar
Update…..
Today I thought I would check the air filter & to my surprise I found a very dirty K&N panel filter. When I say dirty I mean I had to take a flat head & pick out all the dirt & gunk. I cleaned the filter very well & then charged it with K&N oil. I installed the filter & warmed up the car. When I started driving I could feel the difference right away, more responsive on the throttle & it felt like it had some more power. Anyway, could a badly clogged filter cause this code? I mean it would make since if the filter was making it hard for the engine to get air at idle, causing “random misfire” due to lack of air.
luefher
Feb 16, 2012 06:44 PM
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
