help me with nasty noise coming from rear
Old May 13, 2006 | 11:17 PM
kgsolomon1's Avatar
Default help me with nasty noise coming from rear
Once I start going over 20mph i get a repetitive noise that sounds like it is coming from my passenger rear tire. it gets worse and louder as i speed up, and it goes away when I take a left turn, but doesnt change on a right turn. I also have vibrations in the wheel, but i know that all four of my rims have minor dents/bent. Is that prob just my tire that needs replacing or could it be something else?
Old May 14, 2006 | 12:07 AM
Subherb_s4's Avatar
Default RE: help me with nasty noise coming from rear
Sounds like a rear wheel bearing.
This implies it's probably the driver side. When you make a left turn it takes the load off the driver side wheel and hence the noise goes away.
Old May 14, 2006 | 02:28 PM
kgsolomon1's Avatar
Hm, but when i put down my rear seats its clearly coming from the passenger side...
Old May 14, 2006 | 03:30 PM
smithers_0990's Avatar
Jack up the rear end and grab the wheel at 3 & 9 and shake it. If it has any play in it, it's a wheel bearing.
Old May 14, 2006 | 09:18 PM
chebert69's Avatar
I agree with the other fellows for the wheel bearing. Mine did the exact same noise
2 months ago and it was wb.
Dont think you can do it your self unless you have a 2 tons press and a couple hours
to spend. It's a PITA job.
Good Luck !
[IMG]local://upfiles/9918/EE073137E0114273B40A97C901377344.jpg[/IMG]
Old May 14, 2006 | 10:13 PM
AteUrV8's Avatar
whoa...those tail's...
Old May 17, 2006 | 03:25 AM
Audis42001's Avatar
wheel berring most likely! you can get it done for 350.00 probly!
Old May 25, 2006 | 03:56 PM
kgsolomon1's Avatar
Well just got back from the stealership. All four of my wheel bearsing are shot, the right rear one is just completely gone which is why the noise is coming from there. They also said the tie rods in the rear have to be replaced. Luckily my extended factory warrenty covers all the wheel bearings, but tie rods are not coverd. What's with that? I understand brakes and clutch and tires etc., but I figured tie rods would be covered. But the control arms are fine so next tuesday the work is being done. In conclusion, you all are right it was the wheel bearing
Nevalite
Nov 28, 2014 04:31 PM
mchltarr
Dec 13, 2013 04:55 PM
gareth.brown17
Mar 21, 2013 10:46 PM
PrincessBrat
Jun 18, 2009 04:38 PM
Boomshnap
Mar 30, 2008 06:01 PM
