Help needed!!! Having a code saying brake light
Old Feb 17, 2006 | 01:36 PM
LilBlackS4's Avatar
Default Help needed!!! Having a code saying brake light
well i got in my s4 this afternoon and started it up and went to press the brake and i got this beeping and then a warning from the info screen. it says brake light in yellow.
but here is the problem, all the brake lights work, turn signals, reverse light. I even went to autozone and bought new bulbs to replace the ones that looked fine with.
I got done doing that, and i put in my new 710n's and my new samco tbb.
started the car up and the silly light is still there saying brake light. what should i do, has anyone else had this problem.
oh and by the way the springs on the stock 710a dv's were really weak as opposed to the ones on the 710n's (if you press in on them it is a noticable difference.
please any help would be great.
Thomas
ALSO HOW DO I RESET THE SERVICE THING, I TRIED WHAT THE OWNERS MANUAL SAID AND IT IS STILL THERE.
Old Feb 17, 2006 | 06:58 PM
LilBlackS4's Avatar
Default RE: Help needed!!! Having a code saying brake light
anyone?
Old Feb 17, 2006 | 07:15 PM
techbod's Avatar
breaks hmm could be the break fluid level ( I guess you had some one look at the break lights while you had it pressed on ) I know as silly as it sounds sticking new bulbs in without seeing the actualy on does happen
service indicator no problem
[IMG]local://upfiles/12092/10103F62B51143A89F73060CE36A970B.jpg[/IMG]
Old Feb 17, 2006 | 07:28 PM
LilBlackS4's Avatar
my thing says it is time for service, all the lights work, i checked them twice and put in new bulbs, i will check the brake fluid.
how do i do the reset for the service thing, do i need a vag or is there another way.
Old Feb 17, 2006 | 07:31 PM
techbod's Avatar
the picture shows how to reset the service light you only need VAG if its set to long term services,
I assume your car is the 2001 2.7t
Old Feb 17, 2006 | 08:26 PM
LilBlackS4's Avatar
my s4 is a 2001.5, i will try what it says in the pic, thanks
what would it say if it is long term services, also any idea on the brake light problem.
Old Feb 17, 2006 | 08:34 PM
techbod's Avatar
long term service means you wont be able to reset it with those instructions and then you need the diagnostics, break light could be break peddle switch/fluid level/break pads/short in the wiring/bad ground one side being brighter than the other
Old Feb 17, 2006 | 08:55 PM
LilBlackS4's Avatar
it is just weird cause it came on out of the blue.
well i will start checking those things. man i hope it is just the fluid level.
TexasLexus71
Apr 12, 2012 05:38 PM
Scott Long
Mar 26, 2010 10:23 PM
ThePizza
Apr 23, 2008 04:58 PM
