Help...TTb and Blown turbo?
Old Aug 31, 2008 | 12:08 PM
DSMKiller's Avatar
Default Help...TTb and Blown turbo?
I was driving my 00 S4 the other night and when I parked it in the garage I heard a loud whistle noise from the under the hood. I took a look and my TTB had a small leak in it. It makes noise where boost is escaping at ideal, but you can not hear it when you drive. Will this hurt the car in any way. I am going to purchase a new TTB tomorrow.
Also I was driving last night and I was in 6th gear cruising aroung 55 mph, I did not have the radio on and the widnows where up. I noticed at 1/8-1/4 throttle there was a sound coming from the motor. The dentist drill like noise that nobody wants to hear. When I give it full throttle I can not hear it. The turbos seem to be spooling fine. Seems like I am getting full boost when i accelerate, but i do not have a boost guage to be 100% sure. You can not hear the drill like noise at full throttle. Sign of bad turbo or something to do with the TTB?
Old Aug 31, 2008 | 12:19 PM
lilnickx69's Avatar
First thing about the Tbb.
-I wouldnt drive the car with a leak or tear on the TBB as in can lead to damaging the turbos over time.
-If your tbb has a leak you should be able to tell if your car is accerlating slower than normal or you hear excessive air noise from under the hood.
2.) about the turbos.
-If you hear a dentist drill like noise and its loud during the lower rpms (i beleive from 2k-4k) it could be a blown turbo. Only way to be completely sure is have it looked at.
Old Aug 31, 2008 | 12:26 PM
DSMKiller's Avatar
What is the sensor on the TTB? Is it safe to disconnect it?
Old Aug 31, 2008 | 02:09 PM
Rajan147's Avatar
yes it is fine to remove and set it aside when replacing the TBB. Just replace your TBB with a SAMCO one or APR Bi-pipe.
Old Aug 31, 2008 | 03:16 PM
DSMKiller's Avatar
I just back from taking a drive. I have noticed for awhile that when I am driving through my nieghborhood approx. 20mph in 3rd gear, The transmission whines alittle, just in 3rd. Could that whine (drill sound) be coming from the transmission? I do not think one of the turbos are blown, They sound, spool as normal and boost feels the same. Low tranny fluid??? I whine is not relatively loud. Quiet enough that if you where not listening for it you might not hear it.
Old Aug 31, 2008 | 04:08 PM
lilnickx69's Avatar
if the whine sound isnt that loud that you cant notice it unless you listen to it then it is definantly not a blown turbo.
Im not to familiar with the tranny or the fluid being low as i have never came across that problem. But maybe someone else on the forums definantly knows.
Old Sep 1, 2008 | 07:47 AM
SourDieselS4's Avatar
It dosnt sound like you have a blown turbo to me. Our turbos and all turbos for that matter make a spooling/wistleing sound before you hit full boost. When the cars cold it can be a little louder but its still normal. WHen the turbo is blown you should not be questioning it. Its more of a screaming babies very loud obnoxious wine most of the time theres large ammounts of smoke coming from the exhaust
Do fix the boost leak though
Old Sep 2, 2008 | 05:56 PM
DSMKiller's Avatar
The turbos are good I had them checked out. As far as the throttle body boot, it is still good. I could not fins a pin hole or a tear, nothing. When I was re-installing the ttb, I came across a loose bolt on the Throttle body. I checked the others, they where all loose? So I torqued them down and now everything is fine. That whre my leak was coming from.
DSG ROCKS!
Apr 11, 2009 11:32 PM
TopGUn86
Jan 17, 2008 07:39 PM
a4andmore
Jun 22, 2007 10:44 PM
widgget
Feb 22, 2007 06:48 PM
jermdogg143
Aug 3, 2005 03:32 PM
