help w/ cv repair
Old Feb 8, 2009 | 11:46 AM
tbr76's Avatar
Default help w/ cv repair
I was hoping someone could tell me if the bolt holding the upper control arms threads out of the pinch joint or if it is just pushed in. i got the nut off no problem but the bolt has no interest in moving. soaked in pb blaster for a day. everything else is done i just need to pop out the upper control arms from the pinch joint. any help is greatly appreciated.
Old Feb 8, 2009 | 01:40 PM
CamoA6's Avatar
It just pushes in/out. Try turning it to break some rust loose. Or a hammer to hit it out. not as hard as you can though, you do not want to mushroom it.
Old Feb 8, 2009 | 02:16 PM
tbr76's Avatar
thanks much. i thought it just slipped out but it not even turning left me unsure. will give it some persuasion. thanks again
Old Feb 8, 2009 | 03:23 PM
bottlecap's Avatar
good luck getting it back in. i just did a cv repair a couple months ago and that was the hardest part for me. plus it was raining and i was outside so that made it worse.
Old Feb 8, 2009 | 07:40 PM
CamoA6's Avatar
yeah, just leave that rust bust in there when it is out and use a small wire brush or pipe cleaner to get rid of any corrosion.
Old Feb 10, 2009 | 09:08 PM
meatbiscuit's Avatar
that and the pinch bolt can be a real bitch to remove. I've spent LOTS of time removing those ******** on 2 S4s now. It'll come out, just keep working at it. The bolt needs to be replaced if it's giving you that much trouble, put in a new one. Also, apply some anti-seize grease when you bolt it back up. Not sure if it helps since I haven't had a need to remove mine since applying the grease, but it can't hurt.
Old Feb 12, 2009 | 05:42 PM
tbr76's Avatar
thanks guys. i have already gotten two new bolts seeing as though i still need to do the other side. i have deformed the bolt in question already so just waiting to have the time to go back out ot the garage. just gotta get it to move then i will cut the end off with the sawzall. fortunately it is winter and salty so im not in too much of a rush.
DOtheDEW
Nov 21, 2010 10:47 AM
banddr2
Jun 22, 2009 08:10 PM
drewsph84
Jul 24, 2008 12:20 PM
g_1203
Jan 22, 2007 06:54 PM
NH_USA
Jan 9, 2006 11:36 AM
