Howl sound B5 S4
Old Jan 26, 2012 | 10:28 PM
fourringking's Avatar
Default Howl sound B5 S4
Sometimes when I drive my car it makes a mild howl whenever I accelerate. It runs fine!
Is this sound normal?
Thanks for any input you may have!
Old Jan 27, 2012 | 12:37 AM
FonzoB5S4's Avatar
have you removed anything with a metal gasket, then reused the SAME metal gasket?
Old Jan 27, 2012 | 01:32 PM
I wouldn't know. I just bought it few months ago. Would it be the turbos going bad?
Old Jan 27, 2012 | 03:58 PM
FonzoB5S4's Avatar
when the turbos go they usually make a dentists drill kind of noise. check to see if you are leaking any oil from your turbos. remove your skid plate and see if there is any oil on it.
i mentioned gasket because when i had first changed my aux. water pump i removed my throttle body to get to it. when i put everything back together i re-used my original gaskets on the throttle body. the car made a howling noise due to air leaking when i drove.
grissomtd
Sep 3, 2013 06:41 PM
sineo
Jun 11, 2011 07:38 AM
DonnaC5
Nov 5, 2008 05:46 PM
live4mys4
Mar 22, 2005 03:10 AM
