I have some clunking going on..
Old May 16, 2009 | 01:19 PM
thareals4's Avatar
Default I have some clunking going on..
I am having some suspension issues. When i drive over a rough patch of pavement or even accelerate in a turn i hear some clunking going on in the rear end. I think it is the back left but acoustics in cars can be deceiving. It gets bad when i turn to the left, leading me to think it is the sway bar?
Any thoughts?
Old May 16, 2009 | 07:36 PM
bigern45's Avatar
get it up on a rack and look.. its really simple.. i heard noises out of the front end on my car and on a rack i can see three outta four upper control arms bad..
Old May 16, 2009 | 07:37 PM
bigern45's Avatar
and hey, ill have a good used k03 turbo for that passenger blown one in a few weeks if your interested.... ;-)
Old May 16, 2009 | 09:28 PM
thareals4's Avatar
thanks, hopefully ill have enough for some k04's in a little bit.
Old May 17, 2009 | 04:07 AM
bottlecap's Avatar
i doubt its the issue but a common problem with my old e36 was a busted rear shock mount caused a clunking noise. check the bushings on the sway bar but it could easily by a control arm too
Old May 17, 2009 | 04:50 PM
thareals4's Avatar
check
Old May 20, 2009 | 03:59 PM
mys4.org's Avatar
Like said before get you car up on a rack but rather then looks shaking the tire and see if there is any play. Most likely a bushing or maybe a bearing of some sort has gone bad. Don't forget to check the sway bar.
Old May 21, 2009 | 09:25 AM
thareals4's Avatar
thats what i think it is. ill get it on the rack.
Old May 21, 2009 | 01:54 PM
yesss4's Avatar
Loose swaybar is my bet. I've had CV boot issues as well, but that may just be in front.
Old May 21, 2009 | 04:17 PM
thareals4's Avatar
i think it is the sway bar because when i turn to the left, making the car lighter on the left side, it gets worse.
supergoober752
Apr 13, 2010 02:50 PM
mikes_tt
Sep 24, 2008 01:25 PM
jonah5
Aug 21, 2008 12:11 PM
johnstef
Apr 18, 2008 11:32 PM
DLC1.8T
Feb 10, 2006 05:07 PM
