I just replaced my old tires and noticed this plug hanging loose inside of my wheel w
Old Mar 26, 2009 | 07:23 PM
jjock's Avatar
Exclamation I just replaced my old tires and noticed this plug hanging loose inside of my wheel w
I just replaced my old tires on my 2000 S4 and noticed this plug hanging loose inside of my wheel well. My brake wear light on my dash has been on for the past couple months. is this why? what is that plug? i didnt see anywhere i can plug into....
Old Mar 26, 2009 | 09:41 PM
audiS4jls's Avatar
It's the sensor used with stock brakes. Not sure if that's what's causing the brake light to show up on your dash. You can short it out and see if that helps.
Check this link out and see how some guy does it: http://www.audiworld.com/tech/wheel39.shtml
Old Mar 26, 2009 | 09:55 PM
SourDieselS4's Avatar
brake pad wear sensor, not all pads have them. If you got new brake pads that dont have sensors the light will stay on untill you short it out.
Have you brake pads changed recently? Like the day the light came on? Or are they worn down all the way and the other part of the wire is MIA?
Old Mar 26, 2009 | 09:57 PM
bigern45's Avatar
you have to buy new sensors for the brake pads from audi.. just like a benz..
Old Mar 26, 2009 | 10:01 PM
I got aftermarket mintex brake pads and they came with the sensor allready in them, though alot of pads just dont have them, theres no way to add sensors to pads that dont have them. Some pads for porsche calipers have it too so the feature can be retained with a porsche based BBK
Old Mar 27, 2009 | 12:36 PM
jjock's Avatar
no. the light came on months after i changed the brakes. so what is that plug??
Old Mar 27, 2009 | 12:42 PM
The light should come on when your pads are getting low, if the pads dont have sensors (which it appears they dont) then the light should come on as soon as you unplug the old OEM pads
You got pads without sensors, so that plug is where your pads would plug into. If you take a piece of wire and short it out like shown in the link above the light on your dash will go off. Its not a big deal, next time you can buy pads that have sensors int hem if you want
Old Mar 27, 2009 | 09:48 PM
jjock's Avatar
hey thank you!! that works great.. my yellow brake wear warning light went out..
however i still got 1 problem... my yellow ABS light is on and my red emergency brake light is still flashing.. they were both on before i shorted the brake sensor.. i think they are on because my ABS modulator is bad?? does that sound right? how can i fix that? i know a guy online who said he can fix it for like $50.. what do you think?
Old Mar 30, 2009 | 07:31 PM
audiS4jls's Avatar
I had my brakes replaced a little while back when I first got the car. The shop recommended that I put in ceramic brakes along with rotors required for ceramic brakes.
Anyway, I want to change my own brakes this time and was curious if any ceramic brake will work? Are there specific characteristics I need to look into before purchasing ceramic brakes at, let's say, ecstuning.com ?
bristimjet
Sep 23, 2013 03:26 PM
WIAudiChick1
Feb 9, 2011 02:37 PM
leafyrl
Mar 14, 2008 09:47 PM
kriptonik
Jan 20, 2008 01:34 AM
cavecutter
Sep 30, 2007 06:32 PM
