K03 turbo rebuild
Old Apr 3, 2006 | 04:47 PM
AudiS4_190's Avatar
Default K03 turbo rebuild
Has anyone had the turbos ported and new fins installed on them to make them flow more? Like closer to the K04's. The only reason is because my friend just got a set real cheap so when he changes them I'm getting his old K03's. But we were woundering if anyone has done this. It could potentially be alot cheaper then k04s.
Thanks,
Jason
Old Apr 3, 2006 | 11:58 PM
xx18quattroxx's Avatar
Default RE: K03 turbo rebuild
all k04's are is a different inducer blade design... good luck balancing a 100k rpm piece of equipment
Old Apr 4, 2006 | 12:31 AM
AudiS4_190's Avatar
You mean the cold side right?.............................I'm not rebuilding it. (I got skills Just not that many) There is a shop about 10-15 mins away from me that has been in business for 20yrs that would be doing the work. They just do turbos. So just to be clear, your saying that it isn't bigger it just has a different blade design on the cold side? And they charge what they do for them? WoW Let me know if I misunderstood any of this. Please that is why i'm writing this.
Old Apr 10, 2006 | 01:20 PM
AudiS4_190's Avatar
bump
Old Apr 10, 2006 | 05:41 PM
Jestnomen's Avatar
6th Gear
I don't know why anyone would do this. If you are going to have the engine out most people would just do the K04 or buy new stock K03's.
Old Jun 8, 2011 | 08:10 AM
smk777's Avatar
Default Borg Warner K03 K04 turbo charger rebuild / upgrade / hybrid ?
Hey,
I saw your post here about upgrading a K03 turbo by adding fins to the compressor wheel or turbine. I think the compressor and turbine are made of cast metal so welding is not possible.
Talk to Scroll Products they specialize in turbo rebuilding and turbo upgrades for the Borg Warner KKK K03 K04 Series turbochargers. Last I heard they have a new workshop in Bergen County somewhere off Rt.17S in Ramsey, NJ.
They did an upgrade on a set of K03-016 / 017 turbos for a friend, basically they re-profiled the compressor housing and put a larger K04 compressor wheel.
Here is the contact info ask for Sean.
Scroll Products
80 Greenwood Avenue Unit 12
Midland Park, NJ 07432
201-925-0825
Last edited by smk777; Dec 31, 2011 at 03:30 PM. Reason: their shop flooded after the hurricane and changed address
joenelson7687
Jul 18, 2010 08:27 PM
docurley
Feb 21, 2008 06:08 AM
B5luver
Jun 9, 2007 01:17 PM
V8Mustang
Sep 17, 2006 09:30 PM
black991.8tq
May 11, 2006 05:06 AM
