KO4 install
Old May 13, 2006 | 06:11 PM
orionuv's Avatar
Default KO4 install
Aside from the bolts and new gaskets and oil lines is anything else needed to bolt on KO4's to a '00 s4? Do you need different intake piping? will the stock downpipes work? granted you would have less power but im asking if it would bolt up.
Old May 13, 2006 | 09:09 PM
Subherb_s4's Avatar
Default RE: KO4 install
You will need new piping, check ECS tuning for that. The stock downpipes will bolt up. Also, see about "piggie pipes" (gutted pre-cats). Inexpensive alternative to costly dp's. You will be happy you did!
Old May 16, 2006 | 04:06 PM
Hano's Avatar
i'm doing a ko4 upgrade myself currently. all you really need is the gasket kit that is made from ecstuning.com. however, it is best to get a completely new exhaust system (downpipes and cat back). the problem with piggie pipes are that they don't give you the performance you really need for a ko4 upgrade. it's expensive, but to get the ultimate potential out of your ko4 turbos, the best investment. also, it would be a good idea to get a new fueling kit. in mid-june i am going to get one from awe-tuning as well as a new dv's, and bipipe from apr.
Grey2007
Feb 23, 2012 01:17 PM
kevinbednarek
Feb 22, 2012 06:19 PM
Brautty
Jan 21, 2012 12:38 AM
Dave666
Jul 12, 2005 08:47 AM
1996a4
Apr 4, 2005 04:09 PM
