Lift question
Old May 17, 2007 | 12:19 AM
VADER332's Avatar
Default Lift question
Can you use the drive on lift ?( the lift that looks like an H with the rubber padding thats lifts the vehicle by contacting the entire outsideframe just behind the front wheels and just in front of the rear wheels) I need to change tires and just need to know the best lift.
Old May 17, 2007 | 08:40 AM
CamoA6's Avatar
Default RE: Lift question
Look for the lift points under the vehicle. They should be pretty easy to spot. if you cant find them any balenced flat solid space.
Old May 17, 2007 | 09:36 AM
S obsessed's Avatar
you bet you can. In fact on your side skirts there are little arrows pointing at the body pinch weld seams where those little pads can pick that car right up off the ground.
Old May 17, 2007 | 12:22 PM
Coop's Avatar
you can use any lift you want as long as you can get your car on and off it
audilover
Nov 13, 2011 06:25 AM
steveatv3
May 30, 2011 09:45 AM
Slantsixx
B8 Models
Jul 20, 2009 11:05 AM
Big Hank
Nov 12, 2006 02:33 PM
juice88
Oct 18, 2005 01:44 PM
