Lowering
Old Oct 14, 2008 | 02:06 PM
tpc303's Avatar
Default Lowering
I want to lower my S4. So I called my shop and asked and they said the springs themselves are fairly cheap, but it requires about 5 hours of labor. Is this the normal amount of time? they also said I need new shocks and the total would be around 1800. Does this sound right?
Old Oct 14, 2008 | 03:16 PM
SourDieselS4's Avatar
If you ask me, buy some coilovers (stasis street or vogtlands arent too expensive) and DIY http://www.audiworld.com/tech/wheel28.shtml
If thats beyond your capibilitys or you dont have the tools i guess your stuck going to a shop
Old Oct 14, 2008 | 03:38 PM
tpc303's Avatar
I can do coil overs myself I was just looking for a less expensive route, but maybe there isn't one
Old Oct 14, 2008 | 04:33 PM
audi ops's Avatar
Definately not a less expensive route out there. Go for the coilovers, I just put h&r on this weekend myself. Five hours is about right, I had trouble with the front right, but that was all, the rears are a little harder to compress because the springs are smaller, but I just turned down the air gun when I put the spring compressor on.
Old Oct 14, 2008 | 04:39 PM
yesss4's Avatar
Don't skimp and just get springs - you will not be happy with the results. You're better off saving up and doing it right.
Old Oct 14, 2008 | 06:01 PM
meatbiscuit's Avatar
A word of advice, don't just put the springs on. I don't know where you live, but here in Colorado, the roads get pretty f'd up from the snow and driving a lowered vehicle can be real PITA.
Second, it's really nice to see a tiny 3 inch piece of ice in the road in the middle of December and think "oh I can clear that no problem" until you hear the gut-wrenching noise it makes as it shreds the underside of your front bumper and gets stuck under your belly pan.
I had a set of eibachs on bilstein sports and I ended up installing the ECS coil over kit because the ground clearance just wasn't acceptable for the Colorado winters. I don't know where you live, but definitely get coil overs if you live somewhere where you might be on a less than perfect road.
However, the Eibach/Bilstein/ECS kit was awesome, the car handled like a dream.
Springs are cheap, you can pick up the shocks for ~$125 each (as I recall) and the coil over kit is something like $250. For me, it worked out to be a great frankenstein'd set of coil overs.
Old Oct 14, 2008 | 08:33 PM
Audi_Skydiver's Avatar
I was looking at those ECS tuning kits. I think I might look into them more now that someone has actually used them. LOL
Josh
Old Oct 14, 2008 | 11:38 PM
yah, for the money, they're a pretty good deal. Lightweight aluminum collars, all quality hardware -- I recommend.
Old Oct 16, 2008 | 08:30 AM
tpc303's Avatar
yeah I live in Colorado too. Thanks for the advice I think I'll do the ecs kit with H&R's
Old Oct 16, 2008 | 10:58 AM
Keep in mind, the coil over sleeves in the ECS kit are only machined to fit over Bilstein shocks (at least that was the case when I installed the kit, things may have changed since then, check with ECS...).
djnick
Dec 12, 2009 11:07 PM
mikeeace
Dec 1, 2009 12:02 PM
petes4
Mar 9, 2008 08:51 PM
100mhz
Jun 21, 2007 12:57 PM
mark80scu
Apr 13, 2007 08:07 PM
