Name that hose
Old Oct 29, 2006 | 05:47 PM
Volk's Avatar
Default Name that hose
What is this hose and what is it carrying?
(hopefully there is a picture here)
Just asking becuase I touched it and it basically started turning into dust. but it didnt leak I think...
Does it carry air? boost? Does it activate the DV? just wondering if it has anything to do with my recent power loss in addition to the TBB that I will be checking.
Thanks
[IMG]local://upfiles/23590/B0B61DB013D442F98F39C83B8DB2F99B.jpg[/IMG]
Old Oct 29, 2006 | 08:04 PM
Dr.S4's Avatar
Default RE: Name that hose
From memory its air but its ussually the one that connects the 2 DV's together that turns to dust
I had the one u talkin bout replaced and the cross over one coz they crumble
Old Oct 30, 2006 | 07:29 PM
Volk's Avatar
What did you replace them with?
Just some hose from the parts store or did you take it to the dealer? The hose doesn't look to special but I dont want to put something low pressure on something that might be a high pressure line.
Thanks
Old Oct 30, 2006 | 09:41 PM
Dr.S4's Avatar
The shorter one with fuel hose and frayed one a silcone/rubber one that the mech had handy
Speaking of the dealer, i tried to get the clamps for the 2 hoses coz i couldnt get them that small any ware else, and the give me these freakin clamps that are huge and dont fit the recess on the DV's. I showed them and siad that is the rite corresponding part #, then they order some new ones from parts head office just in case and 2 days latter there the same size clamps! D***s![sm=headbang.gif]
Old Oct 31, 2006 | 03:28 PM
Coop's Avatar
If i can decipher your picture correctly, it appears to be the vac. line to the DV's. dont worry about high/low pressure hose, just use vac. hose for air, heater hose for fluids, and fuel line for.....fuel, you guessed it. if you fasten it properly you will not have any failures.
Old Nov 1, 2006 | 12:54 AM
tristate_s4's Avatar
that hose will only see vacuum and as much presure as you run in boost, just replace with proper size hose with new clamps.
as for the diverter valves i have used some old turbonetics blue silicone hose,not sure on th size, but they fit tight and then used some small zip ties to make sure they stay on. I have used zip ties in the past with great sucess.
good luck
Old Nov 2, 2006 | 11:00 PM
Volk's Avatar
Thanks guys,
I replaced the hose yesterday. And it seems to me that my boost delivery is more consitant. Granted it has only been one day. Either way I am glad to have it swapped out.
bmob222
Aug 30, 2013 03:05 AM
Trinion
Dec 2, 2008 09:50 PM
nemohm
Jan 11, 2008 12:34 PM
oneg
Sep 9, 2007 01:26 AM
