NEED HELP FAST!!
Old Jul 6, 2007 | 05:44 PM
S4Taylor's Avatar
Default NEED HELP FAST!!
I am thinking of purchasing an 01' s4 quattro. I test drove it and right when I got out of the parking lot I got on it and it hit 4000 RPMs and bogged down and back up and down almost like it was losing boost or something. After a couple minutes of warming up it ran like a dream. It seems to do this everytime. Anyone have any idea of what this could be. Crack in the coolers causing the turbos to not build enough boost?? computer problem?? dirty fuel filter?? Someone told me it was a feature that prevented the driver to get in and start spoolin at high R's right off the bat. Any info would be helpful. Thanks!
Old Jul 6, 2007 | 09:39 PM
JETSPEED333's Avatar
SoCal Crew Member
Default RE: NEED HELP FAST!!
how many miles??? bad DV maybe?
Old Jul 7, 2007 | 01:33 AM
S4Taylor's Avatar
71,000 miles.........Whats DV??
Old Jul 7, 2007 | 01:37 AM
2k S4's Avatar
How about not getting into the throttle when it's cold?
Sounds like a boost leak, it can be anywhere.
Old Jul 7, 2007 | 01:41 AM
auditech79's Avatar
ORIGINAL: S4Taylor
Now thats a noob question! DV or diverter valves recirculate the charge of air back into the intake after you let go of the gas, same thing as a blow off valve but recirculated. If they are bad they will leak boost pretty badly which could be the reason the car seems to fall on its face when building up some boost.
Old Jul 7, 2007 | 02:51 AM
Brandon2000s4's Avatar
never heard of that...i think they were bsing
Old Jul 7, 2007 | 11:35 AM
Mott Power's Avatar
doesn't limp mode start at lower rpm's than that? and if it's a leak it would do the same at around 2,000 rpm's as well, could be a DV too
Old Jul 7, 2007 | 01:07 PM
GeilKyle2's Avatar
I'm with 2k here, easy on the throttle there hot rod
crappazappa
Mar 11, 2009 03:10 PM
S4RiddeR
Sep 1, 2007 02:39 AM
bmwtoaudi
Jan 15, 2007 10:32 PM
dozentrio
Aug 31, 2006 04:23 PM
