New Rotors... new pads... grinding noise!
Old Nov 13, 2008 | 12:33 PM
elevatorguy's Avatar
Default New Rotors... new pads... grinding noise!
I just put new rotors and pads on my B5S4 and the front driver side rotors and pads rub in one point of a full circle when jacked up and spinning freely. Get it on the road and it becomes a grinding sound - more pronounced when turning or in reverse.
My initial thought was the rotor must be warped. Of course StopTech thinks otherwise... so I'm entertaining suggestions.
Any ideas?
Old Nov 13, 2008 | 01:51 PM
gobucks's Avatar
Could bethe rotor. Have you taken a drive in it yet? Might help seat the newrotors and pads.
Old Nov 13, 2008 | 02:25 PM
audi ops's Avatar
Do you mean like its scratching/etching a circle around in one point the entire way around like a scratch going around a CD? If so that have to be a rotor flaw when it was machined for the finish.
Old Nov 13, 2008 | 02:38 PM
Audi Ops...
No, not the whole way around... just at one point.
For example - if a clock face was drawn on the rotor, the rotor seems to rub with the pad only at 1:00, and nowhere else on the 'clock.'
Old Nov 13, 2008 | 06:30 PM
drev500@aol.com's Avatar
Take off the rotor and make sure there is no debris on the hub that would prevent it from sitting flush against the hub. If that doesnt work then you have a poopy rotor.
Old Nov 15, 2008 | 11:39 AM
CamoA6's Avatar
DUST SHEILD. I can only hope that is it. You can fix it in 5 seconds with a screwdriver. When the dust shield bends in (usually from touching it slightly while changing Pads and/or rotors.) It will make an intermittent rubbing or scrapping.
Good luck.
Old Nov 19, 2008 | 09:06 PM
Well, I found the cause of the noise today. Get this... there was a little piece of the caliper (left over from the casting?) that stuck out a little more on the driver side than on the passenger side. That little chunk was scraping the back of the wheel. I found it because the caliper began to get a marking on it - where it was rubbing - so I ground that chunk off and that was it!
What a relief!
Evidently, because the new pads are so much thicker than the previous pads, the calipers were pushed out that much more... causing the contact. The clearance is so small; I just might get some spacers.
So, anyone looking into a StopTech Stage 2 brake upgrades take heed.
Thanks for all the help, guys!
little_town_audi_owner
Feb 11, 2009 10:22 PM
milo55041
Oct 26, 2007 05:32 PM
milo55041
Oct 8, 2007 09:19 PM
sailfast
Feb 20, 2007 12:32 AM
16w/A4
Feb 22, 2006 08:45 AM
