oil in intake
Old Aug 1, 2007 | 03:34 AM
TL2ts's Avatar
Default oil in intake
[] I have oil in the air cleaner box and intake of our 2000 A6 2.7 tt. It makes for a wonderful bugfog and uses 1-2 qts of oil in 10 minutes or less. Oil also drips from the Rt exhaust pipe.
I have a set of K04s to swap out but need to know if I am overlooking something else. Any ideas ???
Tks
Old Aug 1, 2007 | 04:16 PM
Mott Power's Avatar
Default RE: oil in intake
i suppose you could run a compression test to make sure it isn't the engine, but my guess is turbo
Old Aug 1, 2007 | 05:56 PM
2k S4's Avatar
I bet you have a messed up breather. Remove the end from the Y pipe & see if that's where the oil is coming from. That is about the only place oil can get into the filter box.
Old Aug 1, 2007 | 07:46 PM
shawncumberland's Avatar
wow, oil coming out of the exhaust, your probably going to need to replace your CATs when you resolve your problem...
David Narez
Jun 26, 2013 09:20 AM
lukestaah
Jul 28, 2012 11:26 AM
ryanjayblair
B7 Models
May 28, 2009 05:13 PM
apg96
Jun 28, 2005 05:34 AM
