Plz Help! Where is this VAG Connector?
Old Feb 4, 2008 | 02:02 PM
Crank_S4's Avatar
Member
Default Plz Help! Where is this VAG Connector?
Hi Guys!
I have a Blitz Dual Turbo Timer in my ´00 S4 B5MT
I have already installed the TTand connected the harness. The only thing is, i can´t connectthe ignition cable, because i can´t find the VAGconnector (see on the picture).
I need to tap the black w/blue cable (ignition)
Please Heeeeeeeeeeeelp!
Thank you guys!
[IMG]local://upfiles/42162/2017A236687E47B5BDF6427C8EA4A87C.jpg[/IMG]
Old Feb 4, 2008 | 07:12 PM
TKneedsS4's Avatar
Default RE: Plz Help! Where is this VAG Connector?
Look at the picture.... see the pedals? haha its right above there just about touching the hood release latch.
Good Luck
Old Feb 9, 2008 | 05:12 PM
Crank_S4's Avatar
Member
I´ve got it. Thank you.
TT works.
But there is another problem.
I can not lock the car while the engine is running. I tried to do the alarm fix, i mean the trick with the black w blue cable on position #6 in the fuse box.
Then i could lock the car while it was running, but the heating, the power windows and the turn signals didn´t work anymore.
Anyone know what to do?
Old Feb 10, 2008 | 11:51 AM
Ruggedboy's Avatar
Wow, that’s weird. I installed my Blitz tt a while back & I didn’t run into those problems. Check all your connections, before & after you installed the timer. One thing I ran into, my central locking system has stopped working and I don’t know if it’s related to the timer or if the pump just went died on me. I posted this question once before & some members pointed to the timer as the culprit. I’m about to just eliminate the timer all together just to see if the central locking comes back on line.
stoppre5k
Feb 24, 2011 12:47 PM
aarono_120
May 9, 2010 10:12 PM
happy-55
Feb 23, 2010 11:34 AM
lawrlu
Nov 12, 2008 07:53 PM
KOKJ
Aug 15, 2007 03:29 PM
