problem with RS6 turbo build performance
Old Aug 2, 2009 | 04:09 PM
bigern45's Avatar
yeah.. im definately going to have to change the coil packs, ill just do all 6... the car runs great and pulls hard.. then all of a sudden, pop from the misfire and sputtering begins and then the car limits boost at 10 psi.. till it starts a new misfire log, im assuming.. then it pulls great again.. so ill put in new coils and go from there..
Old Aug 2, 2009 | 09:36 PM
Mott Power's Avatar
I'm guessing you fixed the coolant line?
Really odd scenario... hopefully you're right.
Old Aug 2, 2009 | 10:17 PM
bottlecap's Avatar
nothin dresses up your engine bay like a brand new coolant tank. 35$ for coils?! thats cheap!
Old Aug 2, 2009 | 11:26 PM
bigern45's Avatar
coolant tank is brand new... hose was bad...
Old Aug 2, 2009 | 11:57 PM
jibberjive's Avatar
What dealer are you gettin the coils from for $35? Always good to hear updates from your build and I hope it gets worked out. You should post some vids!
Old Aug 3, 2009 | 12:46 AM
bigern45's Avatar
audi of lexington quoted me a price of 38 a piece.. 20% puts me under 31 for them.. and i dont know.. im gonna start here because its a know weakness. and i know ive been getting coolant on them... then only codes i have are for p1131 and p1113.. internal resistance on both the o2 sensors.. i cant get a misfire code unless i have vagcom hooked up when its doing it.... but oh well.. i can get around just fine.. maybe my stock dv's are busted.. would that cause it? intermittently?? i have a list of needs.. o2 sensors.. stronger dv's, coil packs, control arms.. possibly icm's.. but audi wants 820 for them..
Old Aug 3, 2009 | 12:33 PM
RoboRabbit's Avatar
wow, thats the same problem i was talking about earlier. i hope i dont have to do all the same haha.
Old Aug 3, 2009 | 12:47 PM
  #18
meatbiscuit's Avatar
I didn't see this thread from a few days ago, I would have thrown in my $.02 earlier
Anyhow, Ern (and Mott) -- sounds like classic EGT problems. I had the same problems a while back. It would pull hard sometimes, the it would **** out and immediately cut boost.
Here's the kicker, only one of my EGTs was throwing a code, but they both ended up being bad. Even if you're not throwing a code, it still sounds like the same scenario I was in. Sucks, because the sensors are ~$250 each.
Have fun replacing the driver's side -- it's a lot of fun.
Old Aug 3, 2009 | 04:49 PM
  #19
bigern45's Avatar
okay.. the guy at audi quoted me the coils for the 2.8 v-6.. not the 2.7t.. so yeah.. they are a little more expensive.. but i could only get 3 today, so i replaced the three on the driverside, the ones that were throwing the most misfire numbers.. 1,2 and 3 almost gave me no misfires.. so .. anyways..thats done and drove home fine.. ill drive more tonight and see how well it pulls... i did notice my boost peak was down, instead of peaking at 26 i hit 24.. dont know if thats good or not.. i know i was overboosting at 26 and it scared me a bit.. EPL made this program good for 23.. so 24 is okay.. i guess....
Old Aug 4, 2009 | 10:48 AM
  #20
digdgb's Avatar
Member
what does one mean when then talk about boost taper?
