Question about Gas To ALL B5 Owners
Old Mar 27, 2007 | 10:02 PM
BITRBO's Avatar
Default RE: Question about Gas To ALL B5 Owners
ORIGINAL: Woodhead2k
Do youlet your car warm up for a long time in the morning or let it cool down for a while? At idle the engine runs rich and I noticed during snow storms when I let my car warm up longer a tank didnt last as long. This could contribute to the low distance.
Yes I let it warm up, but usually not that long; only about a minute or so before actually moving. I do, however, drive really slow and shift early (at or around 2k RPM) for the first 10 min or so, or until the engine is at full temp. I absolutely never get into boost until its warm or very close to it though.
ORIGINAL: 2k S4
...Not sure about NGK's, I stick with the stock plugs, & no, they are not hard to change, but the 1st time, expect it to take you 2+hours..
Damn... I might as well do some plug wires if it's gonna be a process. Well, I just read a pretty intertersting thread from Sparkplugs.com about fine wire Iridiums (granted he is a sales man, but the science is legit) so I might go that route:
https://www.audiforums.com/m_404296/tm.htm
Furthermore, the DENSO Iridiums seem to be priced the same as the NGK Double-Platinums (I know they're both overkill longevity-wise, but I happen to believe in the performance/economy gains with precious-metal iginition components - how can you not?):
http://www.sparkplugs.com/results_ap...p;AAIA=1368233
Old Mar 27, 2007 | 11:17 PM
S obsessed's Avatar
Your car actually has a coil on plug setup which puts a coil and spark plug boot right on the plug, leaving you withno wires too change so you won't have to worry about that. Have you checked your air filter lately? A dirty air filter or a racoon or something in your air intake will cause some poor economy. Other then that someone with a scan tool could take a look at your sensor data and check to make sure everything is running within its parameters.
Old Mar 28, 2007 | 02:15 AM
BITRBO's Avatar
Yeah, DUHHH. I should've know they've got the coil packs in each plug wire (just like the VW's)...[sm=sorry.gif]
Well I had both AutoZone and the Dealer run their scanner's, and they got nothing but the faulty CTS code. I bet that's what it is, but I'll def. check the filter, MAF and plugs anyways.I justhope it's not the engine mounts or something, but I doubt it considering the mileage.
Old Mar 28, 2007 | 02:22 AM
Easy's Avatar
wow, glad i got this car! my other car got around 8mpg [:@]Any 5 minute drive to somewhere and back home seemed like it was 1/4 tank
damn 60lb injectors and 520hp
Old Mar 28, 2007 | 02:45 AM
Cameron's Avatar
Not quite my territory (I have a lowly A4 1.8), but I usually only get 180-200mpt. Probably because I am almost always flooring it... Still better mileage than my 302 4-barrel.
Old Mar 28, 2007 | 03:02 PM
brendon2k's Avatar
I seem to get about 19-21 mpg around town and about 25-28 mpg on the freeway. I think if you are getting under 200 miles to a tank, there is something wrong with your car. I know a lot of other cars run very rich and get horrible mileage when the O2 sensor goes but usually that will give you a CEL.
Old Mar 28, 2007 | 03:41 PM
Coop's Avatar
I usually see around 230-250 per tank, but my foot is usually always in the throttle once its warm, seriously how can you resist. Still costs less to drive than my 4-by-Sonoma did, and is just a bit more than my jetta. NGK is OEM equipment for the S4, around 12 beans a plug, suck it up and do it, its not bad. Just make sure the engine is cool before you take them out of the heads, helicoils suck.
Old Apr 2, 2007 | 05:14 PM
  #18
BITRBO's Avatar
ORIGINAL: Coop
So if the DENSO Iridiums are about the same, would you still opt for the OEM NGK's (which I think are Platinum)? Has anybody tried or is currently running these plugs? Is there a DIY on the plugs, or is it pretty straight forward?
myxyzxo
Jul 9, 2009 04:01 PM
myxyzxo
Jul 6, 2009 02:53 PM
manindra
Feb 10, 2009 05:59 PM
eightonezero
Jan 1, 2008 02:40 AM
Mac_17
Jul 17, 2007 08:37 AM
